go41cx operation?
07-14-2016, 01:46 AM
go41cx operation?
I've recently registered go41cx, and I don't understand how to import MOD files into the app. I've put *.mod files in SD card/Android/data/o2s.emul.hp41x/files, but I'm not sure how the next step works. The PDF documentation doesn't seem to be clear to me. Can anyone make some suggestions?
I'm using a Samsung S5 with Android 6.0.1 Thanks Dave |
07-14-2016, 05:16 AM
(This post was last modified: 07-14-2016 05:33 AM by Didier Lachieze.)
RE: go41cx operation?
Hello, first tap on the center of the display to go to the module screen, select Mods then tap on the three dots on the lower right :
Then tap "import" to import the .mods in go41cx, they will appear on the screen. Here with the math module: Now tap on the slot where you want to insert the module and select the module to load : Btw, the SD card location is not SD card/Android/data/o2s.emul.hp41x/files but sdcard/Android/data/o2s.emul.hp41x/files/modules |
07-15-2016, 02:09 AM
Thanks, so I'm not so far off. @ step 2, when I tap "import" no modules appear on the screen. I've got the files in the right directory, is it sensitive to the file name extension? I've got them named *.mod and *.MOD.
07-15-2016, 05:59 AM
(This post was last modified: 07-15-2016 06:01 AM by Didier Lachieze.)
It doesn't seem to be sensitive to the file name extension, I have renamed the MATH.MOD to math1.mod and it was correctly imported on my Sony Z3 Compact under Android 6.0.1.
What is the source of your modules? |
07-16-2016, 01:50 PM
I've downloaded them from *****, as well as one that was posted in the forums here. I just downloaded tried the Advantage ROM
http://www.*****/LibView.cfm?Command=View&ItemID=2 and go41xc didn't see it. |
07-16-2016, 02:13 PM
I've just downloaded the Advantage module from the same location and everything worked fine.
The next thing I can think of is the file location: I don't have an external micro SD Card, I'm just using the internal memory. Do you have a micro SD Card? |
07-16-2016, 04:10 PM
That was it. I was installing them to that path in the MicroSd card. There's a matching path in the internal storage. As soon as I moved the files to internal storage, they showed up when I tried to import them. Thanks for the help!
07-16-2016, 04:23 PM
Great !
