Another Bug in our Prime
07-15-2016, 01:21 AM
Hello dear people
Few words, more images |
07-15-2016, 02:20 AM
RE: Another Bug in our Prime
Mine returns the correct solution. I've tried it with several different settings for handling complex solutions (since you're using csolve), and I still get the right answer.
07-15-2016, 06:09 AM
(This post was last modified: 07-15-2016 06:20 AM by Didier Lachieze.)
I first get the same result as you but I had something assigned to x. After purge(x) I got the correct result.
07-15-2016, 12:28 PM
RE: Another Bug in our Prime | |||
07-15-2016, 03:11 PM
07-15-2016, 10:37 PM
(This post was last modified: 12-15-2016 07:49 PM by d b.)
Dear people, you are right.
Since I have a lot of program in my HP Prime (also in the emulator), always I run the calculator (for example in mi PC), it creats all the variables of the programs again. So "x" has a specific value. When I go to the memory and clear all CAS variables, Matrixes & Lists; the equation gives the correct solution. We hope the devs soon realease another firmware with more features |
