(12C) Modulus
07-15-2016, 02:37 AM
(This post was last modified: 07-15-2016 02:38 AM by Eddie W. Shore.)
(12C) Modulus
HP 12C Modulus
This program takes the modulus of two numbers: Y MOD X = X * FRAC(Y/X) In this program, X > 0 and Y > 0. Code:
Input: Y [ENTER] X [R/S], Result: Y MOD X Test 1: 124 MOD 77 = 47 Test 2: 3862 MOD 108 = 82 |
07-15-2016, 06:32 PM
(This post was last modified: 07-15-2016 07:00 PM by Dieter.)
RE: (12C) Modulus
(07-15-2016 02:37 AM)Eddie W. Shore Wrote: This program takes the modulus of two numbers: That's not a good idea: roundoff errors will spoil the results. Consider your two examples: 124 mod 77 does not return 47 but 46,99999997 3862 mod 108 does not return 82 but 82,00000008 That's why you better use the relation y mod x = y – x * INT(y/x) instead. Code: 01- 34 x<>y That's a bit longer and requires one data register, but it works. The R↓ in line 11 was included to preserve the initiial values in T and Z. Dieter |
07-18-2016, 10:12 PM
RE: (12C) Modulus
(07-15-2016 06:32 PM)Dieter Wrote:(07-15-2016 02:37 AM)Eddie W. Shore Wrote: This program takes the modulus of two numbers: Here's a routine I wrote about a month ago. One step longer, but it uses only the stack and Last-X register. I wrote it for the HP-38C, but the steps are exactly the same for the HP-12C (but the keycodes would be different). For the two examples given by Dieter, it gets the right results. Code: 01- x<>y Regards, Bob |
07-21-2016, 11:36 PM
RE: (12C) Modulus
From "ENTER: Reverse Polish Notation Made Easy", Jean-Daniel Dodin / Keith Jarett, (pg 115):
Code: 01- 36 ENTER |
07-25-2016, 09:17 AM
(This post was last modified: 07-25-2016 10:10 AM by Dieter.)
RE: (12C) Modulus
(07-18-2016 10:12 PM)bshoring Wrote: Here's a routine I wrote about a month ago. One step longer, but it uses only the stack and Last-X register. Great. In the meantime I got exactly the same solution. Many/most other HPs offer a R↑ which can replace the three consecutive R↓, making the program even shorter. (07-21-2016 11:36 PM)RobertM Wrote: From "ENTER: Reverse Polish Notation Made Easy", Jean-Daniel Dodin / Keith Jarett, (pg 115): That's a nice one as well. Here's another 10/11 step solution: Code: 01 ENTER The first four lines copy the content of Y to Z and T while X and Y are left unchanged. However, all these solutions destroy the stack, while the version I initially posted keeps the values of Z and T. That's why it requires one data register. I wonder if it is possible to do it only with the stack, i.e. without a data register, while Z and T are still preserved. Here's another challenge: what about returning y mod x as well as y div x (i.e. the integer quotient of y and x). There are many applications where both values are required at the same time. That's why I once suggested a DIVMOD command for the 34s that returns these two values. Now, what do you think ?-) Dieter |
07-25-2016, 09:46 AM
(This post was last modified: 07-29-2016 05:40 PM by Dieter.)
RE: (12C) Modulus
(07-25-2016 09:17 AM)I Wrote: Here's another challenge: what about returning y mod x as well as y div x (i.e. the integer quotient of y and x). There are many applications where both values are required at the same time. That's why I once suggested a DIVMOD command for the 34s that returns these two values. I just realized that the code in the previous post can be extended easily to return both values at the same time – it's just two more steps: Code: 01 ENTER The same can be done with the Dodin/Jarett program by inserting ENTER R↓ between step 08 and 09. The above version returns the remainder in X and y div x in Y. 3782 [ENTER] 72 [R/S] => 38 [X<>Y] 52 There even is a third useful result: [LastX] => 3744 The largest number ≤ Y that is divisible by X. Dieter |
07-28-2016, 11:01 PM
(This post was last modified: 07-28-2016 11:02 PM by bshoring.)
RE: (12C) Modulus
(07-25-2016 09:46 AM)Dieter Wrote:(07-25-2016 09:17 AM)I Wrote: Here's another challenge: what about returning y mod x as well as y div x (i.e. the integer quotient of y and x). There are many applications where both values are required at the same time. That's why I once suggested a DIVMOD command for the 34s that returns these two values. Nice program. When I run 3782 [ENTER] 72 [R/S], it leaves 38 in X only and 52 in Y, Z, & T. Works for me. Regards, Bob |
07-29-2016, 05:39 PM
(This post was last modified: 07-29-2016 05:43 PM by Dieter.)
RE: (12C) Modulus | |||
