[Request] for [theta x, t,] key
07-30-2016, 02:10 AM
Hello
The [theta x, t,] key just put x repetitively, my idea is:
a tap x -> [x]
Double-click xx -> [y]
3 taps -> [z]
4 taps... -> [t]
5 taps... -> [theta]
Do you agree with this idea?
07-31-2016, 11:21 PM
RE: [Request] for [theta x, t,] key
Better yet have the key put up a soft key menu: x, y, t, theta, n
08-01-2016, 12:47 AM
I think I saw somewhere the idea proposed (change variable in each new keystroke), you know that calculator?
08-03-2016, 01:59 AM
Here's a teaser from one of the projects that I've been working on... hopefully things will be ready for a public release soon. :-)
With user keys on, pressing XTTN in the manner you described will return x,y,z,t,θ (and shift-XTTN will return in caps).
EXPORT MultiTap(K,L1)
  LOCAL Delay:=200;
  LOCAL C:=0;
  LOCAL P:=1;
  LOCAL T:=0;
  REPEAT
    T:=TICKS;
    WHILE ISKEYDOWN(K)==P DO
      IF TICKS-Delay>T THEN
        IF P==1 THEN
          C:=C+1;
        BREAK 2;
    IF P==1 THEN
      C:=C+1;
    P:=ISKEYDOWN(K);
  UNTIL 0;
  RETURN IFTE(C≥1 AND C≤SIZE(L1), L1(C), L1(1));
KEY K_Xttn()
  LOCAL L1:={"x","y","z","t","θ"};
  LOCAL K:=17;
  RETURN MultiTap(K,L1);
KEY KS_Xttn()
  LOCAL L1:={"X","Y","Z","T","θ"};
  LOCAL K:=17;
08-03-2016, 06:16 AM
Nice idea!
Cyrille
08-03-2016, 12:49 PM (This post was last modified: 08-03-2016 12:51 PM by compsystems.)
thanks if is implemented in the next firmware
