Integral oddity
07-31-2016, 09:06 PM
Integral oddity
Integral 1/(x^2 * sqrt(x^2 + 4)) should be (-sqrt(x^2 + 4))/4*x
The prime gives (-x -sqrt(x^2 + 4))/4*x after factorizing or after simplifying. Is this a bug? |
07-31-2016, 09:07 PM
RE: Integral oddity
Version 2016 04 14 (10077)
07-31-2016, 09:14 PM
RE: Integral oddity
When integrating over a specific range such as pi/6 to pi/4, the exact answer converts to a correct approximate answer of ~.303
Am I missing something? |
08-01-2016, 06:17 AM
RE: Integral oddity | |||
08-01-2016, 10:08 PM
RE: Integral oddity
I must be math challenged/rusty...is not the "-x" that Prime produced a variable? How are the 2 answers equivalent?
What has me befuddled is that when made into a definite integral, Prime reports a correct answer. |
08-01-2016, 11:14 PM
(This post was last modified: 08-01-2016 11:17 PM by Dieter.)
RE: Integral oddity
(08-01-2016 10:08 PM)lrdheat Wrote: I must be math challenged/rusty...is not the "-x" that Prime produced a variable? How are the 2 answers equivalent? If you simplify the Prime result... Code: –x – sqrt(x²+4) ...you get the same antiderivative plus a constant. Dieter |
08-02-2016, 02:10 AM
RE: Integral oddity
Thanks!
For some reason, I was seeing the denominator as "4" instead of "4*x". |
