CAS: math expresion -> logical evaluation
08-27-2016, 02:36 PM
How to evaluate an expression with the (=) operator, so that returns a Boolean value (true/false)?
Example 0 = 0 -> true 10*e^5-10*e^10 = 0 -> false I think it takes a function of the type. evaLogic (MathExpre) -> true/false evaLogic ( (10 * e ^ 5) - (10 * e ^ 10) = 0 ) -> false |
08-27-2016, 03:04 PM
(This post was last modified: 08-27-2016 04:06 PM by Didier Lachieze.)
RE: CAS: math expresion -> logical evaluation
What about :
Code: EXPORT EvalLogic(expression) EvalLogic('0=0') -> 1 EvalLogic('0=1') -> 0 EvalLogic('10*e^5-10*e^10=0') -> 0 And in CAS mode you can also evaluate expressions with undefined variables : EvalLogic('2*x = x+x') -> 1 [Edited to support undefined variables] |
08-27-2016, 06:29 PM
subst(x^2+x*y+y^2+x*y=x^2+2x*y+y^2,'=','==')
08-28-2016, 06:55 AM
(08-27-2016 06:49 PM)compsystems Wrote: The flags must be changed manually =(, but that's not the idea, the flags should be changed from the program code, it is to automate algorithms as does the hp 48 hp 50, TI89 ... No need to change the flags if you explicitly simplify the expression : Code: #cas |
08-31-2016, 06:57 AM
RE: CAS: math expresion -> logical evaluation | |||
