Built-in CAS Variables?
02-14-2014, 05:01 PM
The HP Prime User Guide mentions on page 43 the built-in CAS variables:
"(...)However, the built-in CAS variables must be entered in lowercase.(...)" While you can access the built-in Home variables via Vars -> Home I am asking myself where I can access the built-in CAS variables if there are any...? Built-in variables in CAS I have found so far: e, pi, i It's a very basic question, I know ;-) . Many thanks for you help. Regards, Dominik |
02-14-2014, 06:38 PM
RE: Built-in CAS Variables?
Shift+C, tap [Const]
My website: ried.cl |
02-14-2014, 10:54 PM
Just being picky here: Those are constants, not vary-ables. The only CAS variables that I know of (they only work in CAS) are:
Digits -- the value in CAS Settings, page 1, end of line 2 epsilon -- the value in CAS Settings, page 2, line 4 Digits can be set to any integer 1 to 13 (13 shows as 12 in CAS Settings). CAS doesn't like epsilon to be anything larger than 1E-6. If you set it to something larger than 1E-6, CAS will reset it to 1E-6. Those two are the only CAS variables listed on this page: http://holyjoe.net/hp/PrimeVars.htm If any more are discovered, I'll add them to that list. The User Guide refers to "built-in CAS variables named a to z". That's incorrect. In CAS, a through z do not exist until you create them, and when you purge them, they no longer exist... just like any other user-created CAS variable. That's different from Digits and epsilon, which always exist and cannot be purged. <0|ΙΈ|0> -Joe- |
02-15-2014, 06:49 AM
Joe,
Many thanks for your reply and the provided background information. This is very useful for me! Further, I have just bookmarked your HP Prime Vars list. All the best, Dominik |
