Adding Table of constant Units? how?
09-01-2016, 06:07 AM
(This post was last modified: 11-18-2019 11:16 PM by tom234.)
Hello There,
09-02-2016, 06:18 AM
RE: Adding Table of constant Units? how?
Unfortunately I have no solution yet.
Maybe your question would be more visible in the other sub forum: "HP Prime" http://www.hpmuseum.org/forum/forum-5.html |
09-04-2016, 07:31 AM
(This post was last modified: 09-04-2016 07:36 AM by Didier Lachieze.)
I don't think you can define constants per se in the Prime but what you can do is defining global variables that you'll be able to use where you want. However you need to ensure that the name of your global variables don't conflict with the HP Prime predefined variables. Also as they are variables and not constants they can be modified so beware how you use them!
For example you can create a new program called "CONSTANTS", remove the CONSTANT template inside and just add these two lines and press Check: Code: EXPORT AU:=149597870691; You have now created two global variables: ly light year in km and AU astronomical unit in km. You can use these variables to calculate for example the value of a light year in AU in this test program : Code: EXPORT TEST() |
09-04-2016, 09:23 AM
The exported variables are available outside of programs, but there is no way to write protect them. They can easily be changed via command line entry, or other programs, so constants may not be exactly that!
09-04-2016, 10:00 AM
Perhaps creating a new application and assigning all needed constants in the start() part could help.
Arno |
09-04-2016, 06:50 PM
If you need your constants to include units rather than just numbers, there is a complication: CONVERT's second parameter must be 1 unit, not 0.5 unit (using 0.5 in this example to convert between HP AU and my own AU, to make the output value obviously different.
To make Using your own units possible you would want CONVERT to notice that MYAUinAU was a value other than 1 unit and modify the number returned accordingly. Stephen Lewkowicz (G1CMZ) https://my.numworks.com/python/steveg1cmz |
09-09-2016, 06:06 PM
(09-04-2016 07:31 AM)Didier Lachieze Wrote: I don't think you can define constants per se in the Prime but what you can do is defining global variables that you'll be able to use where you want. However you need to ensure that the name of your global variables don't conflict with the HP Prime predefined variables. Also as they are variables and not constants they can be modified so beware how you use them! Thank you you solved the problem and answered my question thank you very much |
09-09-2016, 06:12 PM
(09-04-2016 06:50 PM)StephenG1CMZ Wrote: If you need your constants to include units rather than just numbers, there is a complication: CONVERT's second parameter must be 1 unit, not 0.5 unit (using 0.5 in this example to convert between HP AU and my own AU, to make the output value obviously different. /////////////////// with all due respect to all the programmers C++, Perl, Ruby are a lot easier and more powerful a language than HP C. its making me second guess just using an app on my iPhone to do this calculator thing. Is there a code or language PDF for HP C(language)???????? |
09-10-2016, 08:22 AM
(This post was last modified: 09-10-2016 01:13 PM by StephenG1CMZ.)
(09-09-2016 06:12 PM)tom234 Wrote:(09-04-2016 06:50 PM)StephenG1CMZ Wrote: If you need your constants to include units rather than just numbers, there is a complication: CONVERT's second parameter must be 1 unit, not 0.5 unit (using 0.5 in this example to convert between HP AU and my own AU, to make the output value obviously different. The language users use to program on the HP Prime is called PPL (Prime Programming Language).. Some have referred to it as being like Pascal. www://http://support.hp.com/us-en/product/HP-Prime-Graphing-Calculator/5367459/model/5367460/manuals The most up to date guide to syntax will be that in the on-calculator help. Stephen Lewkowicz (G1CMZ) https://my.numworks.com/python/steveg1cmz |
09-22-2016, 07:11 PM
Ty very much to one and all
your help was greatly appreciated |
06-03-2019, 07:48 PM
(09-04-2016 07:31 AM)Didier Lachieze Wrote: I don't think you can define constants per se in the Prime but what you can do is defining global variables that you'll be able to use where you want. However you need to ensure that the name of your global variables don't conflict with the HP Prime predefined variables. Also as they are variables and not constants they can be modified so beware how you use them! TY |
