HP-41 port blocks available ?
09-07-2016, 02:14 PM
I know there were some of these made a couple of years ago. Does anyone have a source for these? I'm thinking 10-15 of them? Help?
09-07-2016, 02:48 PM
RE: HP-41 port blocks available ?
(09-07-2016 02:14 PM)Gene Wrote:  I know there were some of these made a couple of years ago. Does anyone have a source for these? I'm thinking 10-15 of them? Help?
Have a look here Gene.
Greetings,
    Massimo
09-07-2016, 02:54 PM
Thanks, but I guess I should have been more specific. :-)
The port block I meant was the copper block internal to the HP 41 at the top that the modules plug into and are visible from the top end of the HP 41 with no modules plugged in.
The same piece of copper goes into the battery compartment and often gets corroded.
I remember that someone had some of *these* port blocks made and wondered if any were still around.
Massimo, thank you for your reply even if it wasn't what I was looking for. It's that type of spirit here that helps everyone!
09-07-2016, 03:23 PM
Are you looking for this?
http://www.thecalculatorstore.com/Repair...sion-ports
09-07-2016, 03:26 PM
(09-07-2016 02:54 PM)Gene Wrote:  Thanks, but I guess I should have been more specific. :-)
So you meant Diego's I/O block ;)
Note: the site seems offline by now.
Greetings,
    Massimo
09-07-2016, 03:31 PM
Oops, yes. If anyone communicates with Diego, ask him to check in here. :-) I've sent him an email.
09-07-2016, 03:38 PM (This post was last modified: 09-07-2016 03:40 PM by Massimo Gnerucci.)
(09-07-2016 03:31 PM)Gene Wrote:  Oops, yes. If anyone communicates with Diego, ask him to check in here. :-) I've sent him an email.
I just sent him an e-mail about his website, too.
Greetings,
    Massimo
09-07-2016, 04:39 PM
I have one of the flex circuits made by Diego that is now surplus to my needs.
Paul.
09-07-2016, 04:47 PM
(09-07-2016 03:26 PM)Massimo Gnerucci Wrote:  So you meant Diego's I/O block Wink
FYI - It's up for me, same as usual.
09-07-2016, 04:58 PM (This post was last modified: 09-07-2016 05:12 PM by Massimo Gnerucci.)
WTF? It seems you're right: I just checked on http://downforeveryoneorjustme.com
Time to check my DNS... (or provider filters)
UPDATE
Name resolution OK, trace in 25 hops, I get a timeout for http.
Trying proxies I get: OK from HK and GER, timeout from USA and "Acceso bloqueado por seguridad. Rogamos contacte con su proveedor de hosting // Access denied by security. Please contact your hosting provider" from Romania...
Greetings,
    Massimo
09-07-2016, 08:20 PM
(09-07-2016 04:58 PM)Massimo Gnerucci Wrote:  I just checked on http://downforeveryoneorjustme.com
Time
Didn't know that site, thanks Massimo.
Here's another, with a bit more info, but same basic idea:
http://www.isitdownrightnow.com/
09-07-2016, 08:32 PM
Time
Yeah, there are a few of them.
Didn't know this one: my time to say thank you, Bob.
Greetings,
    Massimo
09-12-2016, 01:06 AM
Try http://www.clonix41.org/Maintenance/IO_B..._Block.htm
