PIC Code for Teenix emulators
09-16-2016, 09:37 AM
Hi all,
Not sure if anyone is a PIC chip experimenter but I have published the source code for the emulators for those that might be interested. It works in conjunction with the PC emulator which is available in the same download.
The PIC is a 16F1519 and will emulate the following calculators,
HP21, HP22, HP25, HP27, HP29C, HP31E, HP32E, HP33E, HP37E, HP35, HP45, HP55, HP65, HP67, HP70, HP80
http://www.teenix.org
cheers
Tony
09-16-2016, 11:09 AM
RE: PIC Code for Teenix emulators
(09-16-2016 09:37 AM)teenix Wrote:  Hi all,
cheers
Tony
Thanks for that Tony,
I'll have a look at that now.
Btw, have you emailed anything in the last two weeks? I don't have access to my kostal email address while I am away during September.
But I might find some time to work on our display data transfer. So it would be good to know if you have made a start on that.
Cheers,
Harald
09-16-2016, 10:37 PM
(09-16-2016 11:09 AM)Harald Wrote:  Thanks for that Tony,
Cheers,
Harald
Hi Harald,
I've been working on replacing my old flight school management software which is proving to be a larger task that I thought. So along with normal work commitments, I haven't had much time to do anything else.
I'll send the HP35 5x8 keyboard modified source code to your address soon. Its a bit messy though :-)
cheers
Tony
09-17-2016, 10:00 AM
(09-16-2016 09:37 AM)teenix Wrote:  Not sure if anyone is a PIC chip experimenter but I have published the source code for the emulators for those that might be interested. It works in conjunction with the PC emulator which is available in the same download.
Wow! I didn't expect that you made it in pure assembler code. That is nowadays a very special ability. My respect and hats off.
Bernhard
09-17-2016, 11:04 AM
(09-17-2016 10:00 AM)PANAMATIK Wrote:  Wow! I didn't expect that you made it in pure assembler code. That is nowadays a very special ability. My respect and hats off.
Bernhard
C is too cryptic for me, Pascal is easy and assembler is ok but hard to fault find on these types of projects.
cheers
Tony
09-18-2016, 09:15 PM
Cheers,
Harald
Hi Harald,
cheers
Tony
Hi Tony,
I didn't mean to rush you. I am very grateful you are doing this at all!
I doubt I'd be able to write anything that large in assembler. Very impressive!
Cheers,
Harald
09-19-2016, 07:18 AM
(09-18-2016 09:15 PM)Harald Wrote:  Hi Tony,
Cheers,
Harald
Not a problem at all :-)
