COMANDO MAP
09-19-2016, 08:56 PM
COMANDO MAP
good afternoon everyone, I want to use the "map " command in a program, but when I boot an error check .
This is the code I have: EXPORT PRUEBA() BEGIN LOCAL a:={},m,X;X:=CAS.X; a:={1,23,45,10,0}; m:=map(a,X→X<10); m; END; I can say where the bad and what is the solution , thanks for your reply . |
09-20-2016, 01:40 AM
RE: COMANDO MAP
If you are using version 10637 try:
EXPORT PRUEBA() BEGIN local a:={},m,X; X:=CAS.X; a:={1,23,45,10,0}; m:=map(a,"X→X<10"); m; END -road |
09-20-2016, 09:27 AM
RE: COMANDO MAP
(09-20-2016 01:40 AM)roadrunner Wrote: If you are using version 10637 try: Do not Forget ; after END Leo |
09-20-2016, 05:41 PM
RE: COMANDO MAP
When CAS functions are used, it is valid to use the expressions in double quotes.
EXPORT PRUEBA() BEGIN local a:={},m; a:={1,23,45,10,0}; m:=map(a,"x→x<10") END; Viga C | TD | FB |
09-20-2016, 07:17 PM
RE: COMANDO MAP
By the way,
Please note, you can alse use user function, like Code:
