INPUT
10-05-2016, 05:16 AM
INPUT
Bonjour
Avec le fireware 10077:
Quote:15. Resolved issue with INPUT choose lists and >9 items
Maintenant dans le fireware 10637, quelle est la limite ?
Merci d'avance.
Hello
With fireware 10077:
Now in the fireware 10637, what is the limit?
Thank you in advance.
Sorry for my english
10-05-2016, 06:13 AM
RE: INPUT
There isn't a limit.
From memory, the problem was when you went over 10 it could sometimes cause problems when you had >10 in a choose list and more then one chooser. The INPUT form could look at the wrong one in some of the internal operations.
TW
10-05-2016, 06:38 AM
RE: INPUT
The problem (if I remember well) was that the number of items was badly calculated when they was more than one choose in the INPUT causing bad display on the 2 choose and crashes..
This being resolved, there is no more limits (beside memory).
Cyrille
10-05-2016, 10:56 AM
RE: INPUT
Thank you, Tim and Cyrille.
