[Request] (*, ×, ·, SPC ) multiplication sign ONLY on history view
10-21-2016, 02:58 AM (This post was last modified: 10-22-2016 11:45 PM by compsystems.)
Hello, I want to see mathematical expressions, as if they were written by hand, one idea is to allow changing the sign of multiplication (*, ×, ·, SPC ) ONLY FOR HISTORY VIEW, When copying the input line, etc.
[Image: handwrittenMathematicicalAlgebraicNotation_image00.png]
10-21-2016, 06:57 AM (This post was last modified: 10-21-2016 07:00 AM by primer.)
RE: [Request] (*, ×, ·, SPC ) multiplication sign in history view
At first reading your request it look very interresting.
But in fact there is probably no chance to have it.
Every request has a cost.
And the cost for this one is quite high IMO. I can says that based on experiance of digit separator setting. Even in 2016 we still had bug fixed related to digit separator (how numbers are displayed or how numbers are read in command that take expression as argument).
Adding another setting that will impact how expressions will to be parsed will have an high cost for sure.
and I don't speak about user confusion (dot can be used in separator AND as multiplication symbol) These confusions will need to be addressed at display and at parsing (someone may type 2.a for 2*a and someone may type 1.2 for 6/5)
Think about program you can download but might not be typed in the same mode as you ? (yes not all progrm use #pragma)
There are many many things to change (with a risk of bug).
All of that has a cost in time.
And I would prefer people at hp to use that time to implement many new features (new functions, new apps) instead of that single cosmetic feature.
Wouldn't you prefer to have a builtin 3D graph ? or builtin QPI feature ?
primer
10-22-2016, 08:54 PM (This post was last modified: 10-23-2016 02:47 PM by compsystems.)
is only impression in (history view),no affects the way writing of expressions, the * multiplication symbol is preserved in the program editor and input line, etc.
Please try run the following program example (HP50g), Here I show my concept =)
PHP Code:
%%HPT(0)A(D)F(.);
MADE WITH HPUserEdit 6
@  version 0.0.3 OCT 23 2016
HOME
'MULT' PGDIR
DIR
  EXAMPLE
{} TMENU
    FONT8STD FONT
"ENTER A EXPRESSION" "'b^2-(4*a*c)'" 0 2 ALG }
INPUT OBJ
    SELECTMULSIGN
  SELECTMULSIGN
-79 SF { } TMENU
"MULTIPLICATION SIGN"
{ { "Asterisk *" SETFONT8STD }
"Cross ×" SETFONT8CROSS }
"DOT ·" SETFONT8DOT }
"Null " SETFONT8NULL } }
FONTTYPE
    CHOOSE
IF
THEN
EVAL
"CONT" « EXAMPLE » }
"EXIT" « 2 MENU FONT8STD FONT » }
TMENU
ELSE
    END
  SETFONT8STD
    1
'FONTTYPE' STO FONT8STD FONT
  SETFONT8CROSS
    2
'FONTTYPE' STO FONT8CROSS FONT
  SETFONT8DOT
    3
'FONTTYPE' STO FONT8DOT FONT
  SETFONT8NULL
    4
'FONTTYPE' STO FONT8NULL FONT
  FONTTYPE
  1
  FONT8STR
"CCB20D10108000803595354554D40283800000E0E0E00000000000E0E0E00000000000E0E0E00000​000000E0E0E00000000000E0E0E00000000000E0E0E00000000000E0E0E00000000000E0E0E00000​000000E0E0E00000000000E0E0E000000000014161F16040000000E0E0E00000000000E0E0E00000​000000E0E0E00000000000E0E0E00000000000E0E0E00000000000E0E0E00000000000E0E0E00000​000000E0E0E00000000000E0E0E00000000000E0E0E00000000000E0E0E00000000000E0E0E00000​000000E0E0E00000000000E0E0E00000000000E0E0E00000000000E0E0E00000000000E0E0E00000​0080C0E1F1E1C08000F1F1F1F1F1F1F1000000000000515100000000000051510000000000000000​004040404040004000A0A0A00000000000A0A0F1A0F1A0A00040E150E041F0400030318040209181​00205050205190610040404000000000008040202020408000204080808040200000A040F140A000​00004040F1404000000000000060604020000000F100000000000000000060600000018040201000​00E01191513111E000406040404040E000E01101C02010F100E01101E00111E00080C0A090F18080​00F110F0010111E000C02010F01111E000F101804020202000E01111E01111E000E01111E1018060​000060600060600000006060006060402080402010204080000000F100F100000010204080402010​00E011018040004000E01151D15010E100E01111F111111100F01111F01111F000E01110101011E0​007090111111907000F11010F01010F100F11010F010101000E01110109111E100111111F1111111​00E04040404040E000010101011111E0001190503050901100101010101010F10011B15151111111​001111315191111100E01111111111E000F01111F010101000E011111151906100F01111F0509011​00E01110E00111E000F140404040404000111111111111E000111111A0A04040001111115151B111​001111A040A01111001111A04040404000F10180402010F100E02020202020E00000102040800100​00E08080808080E00040A0110000000000000000000000F10020204000000000000000E001E111E1​001010F0111111F0000000E1101010E1000101E1111111E1000000E011F110E00040A02070202020​000000E01111E101E01010F01111111100400060404040E0008000C0808080906010109050305090​00604040404040E0000000B051515111000000F011111111000000E0111111E0000000F01111F010​100000E11111E101010000D130101010000000E110E001F0002020702020A04000000011111111E1​000000111111A04000000011115151A000000011A040A011000000111111E101E00000F1804020F1​00C02020102020C00040404040404040006080800180806000000020518000000051A051A051A051​00000180406090F100F10011A040A0110000F111A0A0400000C14040405060400080414040405020​00F12140804021F1003070F0F1F07030000000F1A0A0A0A000204080E11111E00001804020F100F1​0010204080F100F1000080F140F12000000000006190906100004080F180400000004020F1204000​004040404051E0400040E05140404040000000215180808000402040E0909060000000E010F010E0​000000A05141410101609090F0909060000010102040A0110000C02121E02020100000E190909060​000000E15040418000000090115151A000000040A011F10000F1A0A0A0A0A0A000E011111111A0B1​000000E0E0E00000000000A05151A00000C02170207021C00040004040404040000040E15050E140​00C02120702020F10011E0111111E011001111A0F140F140004040400040404000C020E011E08060​00A000000000000000E01171317111E0006080E09060F000000041A050A0410000000000F0800000​00000000F000000000E0117171B111E000F100000000000000E0A0E00000000000004040F14040F1​00E080E020E0000000E080E080E000000080400000000000000000009090907110E1717161414161​0000000060600000000000000000408060604040E000000000E01111E000F100000050A041A05000​001090502051C10100109050A1118081003021B06071C10100400040201011E0002040E011F11111​008040E011F111110040A0E011F1111100A050E011F1111100A000E011F1111100E0A0E011F11111​00A15050F15050D100E011101011E080602040F110F010F1008040F110F010F10040A0F110F010F1​00A000F110F010F1002040E0404040E0008040E0404040E00040A0E0404040E000A000E0404040E0​0060A0217121A0600041A01131519111002040E0111111E0008040E0111111E00040A0E0111111E0​00A050E0111111E000A000E0111111E0000011A040A011000001E0915131E01000204011111111E0​00804011111111E00040A000111111E000A00011111111E000804011A0404040007020E021E02070​00E011F01111F010102040E001E111E1008040E001E111E10040A0E001E111E100A050E001E111E1​00A000E001E111E100E0A0E001E111E1000000B141F150F1000000E11010E180602040E011F110E0​008040E011F110E00040A0E011F110E000A000E011F110E000204000604040E000804000604040E0​0040A000604040E000A00000604040E00080C180E09090600041A000F011111100204000E01111E0​00804000E01111E00040A000E01111E00041A000E01111E000A00000E01111E000004000F1004000​00000061905121D000204000111111E100804000111111E10040A000111111E100A00000111111E1​008040001111E101E00010709090701010A000001111E101E0"
FONT8STD
    FONT8STR H
  FONT8NULL
    FONT8STR 707
"00000000000000000" REPL H
  FONT8CROSS
    FONT8STR 707
"0011A040A01100000" REPL H
  FONT8DOT
    FONT8STR 707
"0000C0C0000000000" REPL H
END
'MULT' STO MULT
convert to triGraphs format with debug4x IDE http://www.debug4x.com/
PHP Code:
%%HPT(0)A(D)F(.);
HOME
'MULT' PGDIR
DIR
  EXAMPLE
TMENU
    FONT8STD
\->FONT
INPUT OBJ\->
SELECTMULSIGN
SELECTMULSIGN
79 SF { } TMENU
"Cross \.x" SETFONT8CROSS }
"DOT \183" SETFONT8DOT }
FONTTYPE
    CHOOSE
IF
THEN
EVAL
"CONT" \<< EXAMPLE \>> }
"EXIT" \<< 2 MENU FONT8STD \->FONT \>> }
TMENU
ELSE
    END
SETFONT8STD
'FONTTYPE' STO FONT8STD \->FONT
SETFONT8CROSS
'FONTTYPE' STO FONT8CROSS \->FONT
SETFONT8DOT
'FONTTYPE' STO FONT8DOT \->FONT
SETFONT8NULL
'FONTTYPE' STO FONT8NULL \->FONT
FONTTYPE
  1
  FONT8STR
FONT8STD
FONT8STR H\->
FONT8NULL
FONT8STR 707 "00000000000000000" REPL H\->
FONT8CROSS @"×"
FONT8STR 707 "0011A040A01100000" REPL H\->
FONT8DOT @"\183"
FONT8STR 707 "0000C0C0000000000" REPL H\->
END
'MULT' STO MULT
