Negative sign
10-27-2016, 06:18 PM
Negative sign
I noticed that the negative sign in front of a fraction is barely visible. Try 1/2 and then the +/- key to see what to see what I mean.
10-28-2016, 07:11 PM
RE: Negative sign
(10-27-2016 06:18 PM)johnet123 Wrote: I noticed that the negative sign in front of a fraction is barely visible. Try 1/2 and then the +/- key to see what to see what I mean. Are you using the large font? It is worsened by that font size My website: ried.cl |
10-28-2016, 11:39 PM
RE: Negative sign
Yes, I was using the large font. Reducing the font size appears to correct the problem. I guess if you have bad eyesight, as I do, it is a choice between seeing the numbers and characters or the unary minus sign.
