Built-in help for Ans
10-31-2016, 11:54 AM (This post was last modified: 11-01-2016 09:37 AM by JMB.)
I think I have spotted a gramatical error in the translation from English to Spanish and French in the help for Ans.
In English the help says: ... Ans(n) will attempt to substitute n for x (or the default variable)...
This means in English that n will take the place of x (Ok)
In Spanish the help says: ... Ans(n) tratará de sustituir n por x (o la variable predefinida) ...
This means in Spanish that x will take the place of n (Wrong)
It should be: ... Ans(n) tratará de sustituir x (o la variable predefinida) por n ...
In French the help says: ... Ans(n) va tenter de substituer n pour x (ou pour la variable par défaut) ...
This means in French that x will take the place of n (Wrong)
It should be: ... Ans(n) va tenter de substituer x (ou la variable par défaut) pour n ...
I don't know how other languages work regarding this concept, but I guess that the Portuguese translation is also wrong. Perhaps other users fluent in these languages can help in sorting this out.
10-31-2016, 02:14 PM (This post was last modified: 10-31-2016 05:09 PM by compsystems.)
RE: Built-in help for Ans
CAS MODE
Example #1
x [enter] x
Ans*3 [enter] 3*x
Example #2
x [enter] x
Ans(3) [enter] x(3) // == x|(3)
Example #3
f1(x):=x^2 [enter] x->x^2
Ans(3) [enter] 9 // == f1(3)
Example #4
x*y^2 [enter] x*y^2
Ans(x=3) [enter] 3*y^2
PD: is required a similar cmd ENTRY(#) to call an expression (line #) of history, this is available in Xcas
10-31-2016, 06:27 PM
Thank you compsystems, but I am not questioning the calculator's behavior; I'm just saying that the Spanish and French translations of the built-in help for the command Ans should be revised.
10-31-2016, 09:54 PM
In Spanish even your correction is wrong. You cannot say "se sustituir" it must say "de sustituir".
My website: ried.cl
11-01-2016, 09:35 AM (This post was last modified: 11-01-2016 09:38 AM by JMB.)
You're right eried. I have corrected my misspelling. Thanks!
