[Help: CAS Code] Comparing answers history view
11-02-2016, 07:56 PM
(This post was last modified: 02-10-2018 07:01 PM by compsystems.)
Example #1:
Steps Step 1: root:=√(2.) [enter] 1.41421356237 Step 2: exact(root) == approx(root) [enter] true Where: left(exact(root)) ->1607521/1136689 right(approx(root)) -> 1.41421356237 then 1607521/1136689 == 1.41421356237 -> true now Step 3: approx(root) [enter] 1.41421356237 Step 4: exact(root) [enter] 1607521/1136689 Step 5: Ans == [up][up][up] -> (0) false 1607521/1136689 == 1.41421356237 -> 0 // expr 2 Why two different answers? 1607521/1136689 == 1.41421356237 // expr1 1607521/1136689 == 1.41421356237 // expr2 expr1 same expr2 yes |
11-02-2016, 08:01 PM
RE: Comparing expressions
Because they are two different things.
11-02-2016, 08:31 PM
Si quieres comparar 2 datos, puedes crear un función que identifique si es una 'expresión', en caso de serlo lo evaluas, y puedes realizar la comparación.
Viga C | TD | FB |
11-02-2016, 11:23 PM
(This post was last modified: 11-06-2016 04:36 PM by compsystems.)
RE:
(11-02-2016 08:01 PM)Tim Wessman Wrote: Because they are two different things.Ok Ans Documentation A value in Ans is stored internally with the full precision of the calculated result, (11-02-2016 08:31 PM)Carlos295pz Wrote: Si quieres comparar 2 datos, puedes crear un función que identifique si es una 'expresión', en caso de serlo lo evaluas, y puedes realizar la comparación.ok http://www.hpmuseum.org/forum/thread-7173.html |
11-03-2016, 08:24 PM
RE: [Help: CAS Code] Comparing math expressions
Una modo simple en HOME
PHP Code: Igual(Dat1,Dat2) Pruebas: Igual(0.75, 3/4) -> true Igual(2, 4/2) -> true Viga C | TD | FB |
User(s) browsing this thread:
