200LX Desktop Emulator - Teaching an old horse ...
11-05-2016, 11:44 PM
(This post was last modified: 11-05-2016 11:52 PM by Peter A. Gebhardt.)
It's astounding which solutions become possible with the HP Desktop software Version 1.02.
The core of a solution to create a paper trail of results of solver equations - and further iterations in conjunction with Ubuntu 14.04 - is the (clever) combination of readily available commands to read an process the 'tcalc_xxx.prt' files created by consecutive ALT-->FILE->PRINT->DATA: Code: diff --suppress-common-lines -w -b -y -W 200 $CAPTURE/tcalc_"$i".prt $CAPTURE/tcalc_"$j".prt | cut -b110-146 | sed 's/^ *//g' | awk '{printf ("%s\n", $0) }'| awk 'BEGIN{FS="=";} Which produces the sample output: Code: Die nachfolgenden Iterationen dokumentieren alle Eingaben und Änderungen, The final output sample is in German (I've added a dictionary and a translation step), but I think you'll get the picture. Best regards |
11-09-2016, 03:14 PM
(This post was last modified: 05-21-2024 02:00 PM by Peter A. Gebhardt.)
RE: 200LX Desktop Emulator - Teaching an old horse ...
Addendum
------------ My environment is - "from in to out": - HP 200LX Connectivity Pack 1.02 - Last release! - (LINUX) https://github.com/ykhwong/dosbox-svn-da...t_linux.7z (DosBOX w/Print!) [as of May 21st, 2024] - (WINDOWS) https://github.com/ykhwong/dosbox-svn-da...up_win.exe (DosBOX w/Print!) [as of May 21st, 2024] - Ubuntu 14.04.5 32-bit - Windows 10 Best regards |
