Fiber Optics EQ Library
11-19-2016, 03:07 AM
(This post was last modified: 10-14-2019 08:07 PM by BERNARD MICHAUD.)
Fiber Optics 2 Library, Upgrade Oct. 12/19, is a set of Equations that can be used in a course in Fiber Optics, based on the book "The Elements of Fiber Optics" by S.L. Wymer Meardon, 1993.The variables may vary slightly, but a variable description is provided in each topic.
There are four constants used. 1-h=6.626E-34 Joules/second Planck's constant. 2-q=1.602E-19 Coulombs, electron charge. 3-c=2.998E8 m/s, speed of light in a vacuum. 4-k=1.381E-23 Ws/K, Boltzmann's constant. There are a total of ~ 130 variables all listed with a description. BM |
11-19-2016, 04:36 AM
RE: Fiber Optics EQ Library
Inside the code does not find the file ENGLIB();
11-19-2016, 02:54 PM
You can ignore that. An oversight , I used my ENGLIB program as a Template.
I'll remove it when I get a chance and repost it. Thanks |
11-19-2016, 03:04 PM
OK DONE Thanks for the heads up.
BM |
