Thread for 67FUN2 game rom program development
11-22-2016, 08:02 PM
No, I'm not suggesting a "jump right in" approach to this, but I'm posting a candidate or two for the next effort. As time permits, optimizing these can move ahead.
Robert has a version of a game of Bowling. Not a bowling scorekeeper program, but one that allows you to bowl. Post it in this thread when you can.
Here is a game I have hastily rewritten from a HP 67 User's Library program: Paper, Rock, Scissors.
Goal: Choose paper, rock or scissors and try to beat the calculator. Get to a score of 10 wins first to beat it. Each win is +1. Each loss is -1. Paper is A, Rock is B and CUT (scissors is too long) is C.
Obviously, the Seed? and RN routine would be modified as we did in 67FUN previously.
.raw file: PRS
Original program PDF - note that this has been modified already, but for reference purposes: PDF
And text listing of program here:
 01 LBL "PRS"
 02 "SEED?"
 03 PROMPT
 04 STO 00
 05 FIX 00
 06 CLX
 07 STO 01
 08 RTN
 09 LBL A
 10 SF 01
 11 1
 12 GTO 00
 13 LBL B
 14 SF 02
 15 2
 16 GTO 00
 17 LBL C
 18 SF 03
 19 3
 20 LBL 00
 21 XEQ 01
 22 3
 23 *
 24 1
 25 +
 26 INT
 27 STO 02
 28 X=Y?
 29 GTO 05
 30 1
 31 -
 32 X=0?
 33 GTO 02
 34 1
 35 -
 36 X=0?
 37 GTO 03
 38 FS? 02
 39 GTO 06
 40 LBL 07
 41 1
 42 ST- 01
 43 "LOSE"
 44 GTO 08
 45 LBL 02
 46 FS? 02
 47 GTO 07
 48 GTO 06
 49 LBL 03
 50 FS? 03
 51 GTO 07
 52 LBL 06
 53 1
 54 ST+ 01
 55 "WIN"
 56 LBL 08
 57 >" "
 58 ARCL 01
 59 AVIEW
 60 PSE
 61 PSE
 62 PSE
 63 "Y:"
 64 FS?C 01
 65 >"PAP"
 66 FS?C 02
 67 >"ROCK"
 68 FS?C 03
 69 >"CUT"
 70 >" HP:"
 71 RCL 02
 72 1
 73 -
 74 X=0?
 75 >"PAP"
 76 1
 77 -
 78 X=0?
 79 >"ROCK"
 80 X!=0?
 81 >"CUT"
 82 PROMPT
 83 RTN
 84 LBL 05
 85 "TIE"
 86 GTO 08
 87 LBL 01
 88 RCL 00
 89 R-D
 90 FRC
 91 STO 00
 92 END
11-22-2016, 10:37 PM (This post was last modified: 11-22-2016 11:21 PM by Dieter.)
RE: Thread for 67FUN2 game rom program development
(11-22-2016 08:02 PM)Gene Wrote:  Here is a game I have hastily rewritten from a HP 67 User's Library program: Paper, Rock, Scissors.
How do you like the attached version?
The program uses a very compact evaluation routine – no flags, no elaborate tests, and the XROM version does it in 157 bytes.
PRS2a has its own seed prompt and RNG, while PRS2_XROM uses the two XROM functions of the Games ROM.
XEQ "PRS"        SEED?
0,12345 [R/S]    SCORE: 0
  [A]            YOU-PAPER
                  HP-ROCK
                 YOU WIN
                 SCORE: 1
  [B]            YOU-ROCK
                  HP-SCISSORS
                 YOU WIN
                 SCORE: 2
  [C]            YOU-SCISSORS
                  HP-SCISSORS
                 A TIE
                 SCORE: 2
  [B]            YOU-ROCK
                  HP-PAPER
                 YOU LOSE
                 SCORE: 1
The program uses a synthetic RCL d/STO d to save/restore the display setting.
BTW, there also is an alternate version that displays both players in one line:
  [B]            ROCK
                 ROCK : SCISS
                 YOU WIN
                 SCORE: 2
Dieter
Attached File(s)
.zip  PRS2.zip (Size: 1.52 KB / Downloads: 5)
11-23-2016, 01:21 AM
Great, thank you.
Here are a few more to have on file here as time permits for anyone to convert to the HP 41. I'm well aware this is a LONG term effort, but just in case - :-)
HP-33E Time Traveler
HP-67 Catch me
HP-67 Mine Field
HP-67 Pegs
HP-67 Othello from the museum posting
HP-67 Shooting Gallery
Then some .raw files we had seen before but deferred:
HP-67 Wari
HP-67 Roulette
Bell Fruit Slot machine - another good one
Here is a link to a 50MB .zip file of some HP-67 programs - some from PPC and some from the User's Library: Worth downloading... .zip of HP-67 programs
11-23-2016, 01:58 PM (This post was last modified: 11-23-2016 02:07 PM by Dieter.)
(11-22-2016 10:37 PM)I Wrote:  The program uses a very compact evaluation routine – no flags, no elaborate tests
Maybe I should explain how this works.
Let Paper=3, Rock=2 and Scissors=1. If a and b are the moves of the two players, then (a–b) mod 3 returns 1 or 2 if the first resp. second player wins. Zero represents a tie. This works if –2 mod 3 is evaluated as 1, like the 41 does it (on the 34s use MOD, not RMDR). On calculators without mod function you simply add 3 if a–b is negative. You can even go one step further and calculate 2x this minus 3 to get –1 or +1 for the score counter (a tie has to be handled separately).
If you prefer Paper=1, Rock=2 and Scissors=3, as in the original program, simply replace a–b with b–a. Or change the logic (1 = player 1 loses, 2 = player 2 loses).
So the score evaluation in PRS2a can be done in just three steps (51...53): Y and X hold the player's and HP's move, and "– 3 MOD" yields 1 (player wins) or 2 (HP wins) or 0 (a tie). In the latter case the program jumps to LBL 04, else the test whether X is 1 or 2 is done with a DSE X. This yields 0 or 1, and if it's 1, DSE tests true and jumps to LBL 05 (HP wins), else the player wins.
Another elegant option could be a simple indirect jump. This method is used in the following variation of the game. Here also the original definition Paper=1, Rock=2 and Scissors=3 was used and the both players' moves are displayed in one line. Here is the listing:
 01 LBL "PRS"
 02 RCL 00
 03 "SEED?"
 04 PROMPT
 05 ABS
 06 FRC
 07 STO 00
 08 SF 27
 09 LBL E
 10 CLX
 11 STO 01
 12 LBL 10
 13 RCL d
 14 FIX 0
 15 CF 29
 16 "SCORE: "
 17 ARCL 01
 18 STO d
 19 RDN
 20 RCL 01
 21 AVIEW
 22 RTN
 23 LBL A
 24 1
 25 GTO 00
 26 LBL B
 27 2
 28 GTO 00
 29 LBL C
 30 3
 31 LBL 00
 32 CLA
 33 XEQ IND X
 34 AVIEW
 35 PSE
 36 RCL 00
 37 PI
 38 +
 39 X^2
 40 FRC
 41 STO 00
 42 3
 43 *
 44 1
 45 +
 46 INT
 47 >" : "
 48 XEQ IND X
 49 AVIEW
 50 PSE
 51 -
 52 3
 53 MOD
 54 4
 55 +
 56 XEQ IND X
 57 ST+ 01
 58 AVIEW
 59 PSE
 60 PSE
 61 GTO 10
 62 LBL 04
 63 "A TIE"
 64 CLX
 65 RTN
 66 LBL 05
 67 "YOU LOSE"
 68 -1
 69 RTN
 70 LBL 06
 71 "YOU WIN"
 72 1
 73 RTN
 74 LBL 01
 75 >"PAPER"
 76 RTN
 77 LBL 02
 78 >"ROCK"
 79 RTN
 80 LBL 03
 81 >"SCISS"
 82 END
That's 161 Bytes including seed prompt, RNG and an additional restart label E.
If you don't know how to enter the synthetic RCL d and STO d commands, simply replace line 18/19 with FIX 4  SF 29 and omit the RCL d in line 13.
Dieter
11-23-2016, 09:18 PM (This post was last modified: 11-24-2016 07:30 AM by Dieter.)
(11-22-2016 10:37 PM)Dieter Wrote:  BTW, there also is an alternate version that displays both players in one line:
  [B]            ROCK
                 ROCK : SCISS
                 YOU WIN
                 SCORE: 2
The one-line display of course works best if the three symbols do not have more than six, perferably five characters so that they fit the 12-character display of the 41. I tried this with a localized version in German (with "Stein", "Papier", "Schere" – all with 5 or 6 characters) which at least fits with a colon as a separator. How would you do this in English? Maybe replace the rock with a stone and the scissors with a knife ?-) This would fit the display perfectly.
BTW, in Germany this game is called "Schnick-Schnack-Schnuck". I think this sounds much more charming than "Stein, Schere, Papier". ;-)
Dieter
