[IDEA CAS] increasing flag -> increasing cmd
11-26-2016, 05:21 PM
(This post was last modified: 11-26-2016 08:04 PM by compsystems.)
Hello CAS programmers
1: increasing flag: off reorder(a+b+c,[c,b,a]); -> c+b+a // ok increasing flag: on reorder(a+b+c,[c,b,a]); -> a+b+c // =( I think the order is lost, because the increase operation is applied at the end 2: increasing flag: off (^3->^2->^1) reorder(a +b^2+b +c^3+c^1,[c,b,a]); -> c^3+c^1 +b^2+b^1 +a // ok increasing flag: on (^1->^2->^3) reorder(a +b^2+b +c,[c,b,a]); -> a^1+ b^1+b^2 +c+c^3 // It is more useful that the increment flag is only made in each subpolynomial reorder(a+b^2+b+c,[c,b,a]); -> c^1+c^3+ b^1+b^2 +a^1 3: increasing flag: off (^3->^2->^1) & (x->y-z) I think the variable should also decrease (z->y-x) collect(x^3+y^3+z^3+x^2+y^2+z^2+x+y+z) -> x^3+x^2+x +y^3+y^2+y +z^3+z^2+z // Collect by polynomials of the same variable collect(x^3+y^3+z^3+x^2+y^2+z^2+x+y+z) -> z^3+z^2+z +y^3+y^2+y +x^3+x^2+x increasing flag: on (^1->^2->^3) & (z->y-x) =( collect(x^3+y^3+z^3+x^2+y^2+z^2+x+y+z) -> z+z^2+z^3 +y+y^2+y^3 +x+x^2+x^3 =( collect(x^3+y^3+z^3+x^2+y^2+z^2+x+y+z) -> x+x^2+x^3 +y+y^2+y^3 z+z^2+z^3 =) 4: simplify(x^3+y^3+z^3+ x^2+y^2+z^2 +x+y+z + w+w); 2*w +x^3+x^2+x +y^3+y^2+y +z^3+z^2+z The (increasing flag: on) does not operate correct answer x+x^2+x^3 +y+y^2+y^3 +z+z^2+z^3 +2*w To avoid the whole problem of INCREASING FLAG, this must be deleted from CAS settings, and better be replaced by a command In/Decreasing Only powers, for more of 2 variables the user orders them with the REORDER command Increasing (expr); Decreasing (expr); Good Idea? ---- In this way I can have control of the outputs and manipulate them with commands to extract parts, REORDER control is lost and more, otherwise it is very difficult to program on HP-PrimePL (HP-PPL) |
