WP 34S Integration Speed
02-21-2014, 03:55 AM
Is there a way to balance accuracy with speed of integration on the 34S as with HP's that can integrate? The HP's give the user the ability to require, say, 4 significant digits of accuracy vs. the full 12 digits in order to arrive at a result in a significantly shorter amount of time. Can this be accomplished on the wonderful 34S?
02-23-2014, 06:35 PM
RE: WP 34S Integration Speed
(02-21-2014 03:55 AM)lrdheat Wrote:  Is there a way to balance accuracy with speed of integration on the 34S as with HP's that can integrate?
You have posted the same question in the General Forum, where it has been answered in detail. Accuracy control is essentially the same on the 34s as on classic HPs like the 34C or 15C: simply adjust the display format accordingly.
For more details cf. this topic in the General Forum.
Dieter
