[REQUEST] reset field ([<-] key) "input" cmd
12-07-2016, 01:10 PM
(This post was last modified: 12-07-2016 10:21 PM by compsystems.)
Hello hp-prime developer group
Request/Idea: I: Pressing the [<-] key, generates a popup or menu showing: 1: Reset [current] value 2: [All] 3: [exit] II: Type valids with [HELP] key (INFORM cmd of the hp48/50) do this. PHP Code: « Purpose: Avoid accidental deletion of fields. Currently pressing the [<-] key, deletes the current field of input cmd, sometimes it is uncomfortable because the [<-] key, is not visible in the menu ([edit] ... [cancel] [ok]) of INPUT and can be accidentally pressed. What do programmers and users say about this idea? |
12-07-2016, 08:55 PM
(This post was last modified: 12-07-2016 09:07 PM by compsystems.)
RE: [REQUEST] reset field ([<-] key) "input" cmd
I found a problem when resetting values with [<-] key, by default always set 0, this should not be so because it is not always the value of the correct defined data type
These are the default reset values that do not generate INVALID DATA TYPE and that should be implemented, not in the following firmware but if in the future, you agree? Quote:-1: all -> EMPTY FIELD (NULL) Test each field from the following code, Comment and uncomment for each case If you press [<-], then [edit] menu -> "Error: Invalid Input" PHP Code: export input0() A help for data types |
