[SOLVED] CAS `solve` crash on simple expression with two variables
12-18-2016, 06:25 AM
(This post was last modified: 12-18-2016 08:34 AM by danielmewes.)
UPDATE: I got this working by re-flashing the firmware, using the procedure described here http://www.hpmuseum.org/forum/thread-404...l#pid65729 . So it looks like this was a false alarm.
Steps to reproduce: 1. Enter CAS mode 2. Enter `solve(x*y=0)` 3. Press Enter to evaluate 4. If the calculator doesn't reboot immediately, copy and evaluate the command a few more times (the first time seems to be enough to corrupt memory, but it doesn't always reboot immediately) Observed behavior: Calculator reboots Software Version: 2016 08 29 (10637) I did a reset to factory settings. I also tried reproducing this on the Android emulator, but wasn't able to do so. I'm not sure if this is a regression or not. Is anyone still running an older firmware and willing to test this out? Video of the crash: https://www.youtube.com/watch?v=O6dDDgE1QcE |
12-18-2016, 07:00 AM
RE: [Bug] CAS `solve` crash on simple expression with two variables
In addition to the Android version, I also can't reproduce this with neither Giac 1.1.4 nor 1.2.2 on Linux. Though it's possible that there's still memory corruption, and it just doesn't cause a crash.
12-18-2016, 08:25 AM
I checked giac with valgrind, no memory corruption detected.
12-18-2016, 08:31 AM
Thanks for checking!
I think it might have been a false alarm. Sorry about that. I just downgraded my calculator to 2016 06 17 and the crash didn't occur anymore. Then I upgraded back to the latest 2016 08 29, and it's still working fine. My only explanation is that the firmware on my Prime somehow got corrupted when I updated it earlier today. It did hang at the end of the update and I had to reset it, though the connectivity kit said that the update had been complete at that point. |
12-18-2016, 10:08 AM
RE: [SOLVED] CAS `solve` crash on simple expression with two variables
If I recall correctly, it was suggested to create a backup, then "Format Disk C," (Using the prime's C-F-O [ON], Option 4, utility), before launching the upgrade. This might have prevented that problem.
-Dale- |
