Possible BUG on History CAS
01-06-2017, 08:21 PM (This post was last modified: 01-06-2017 09:52 PM by compsystems.)
Hello
Quoted expressions ('expression') are not working well in CAS history
F1(x):='sin(x)'; ⇨ 'sin(x)'
[up key] QUOTE(sin(X))
f2(x):=quote(sin(x));
[up key]
f1:=(x)->'sin(x)'
f(x):=x^2;
f(x)' ⇨ 2*x // ok
f' ⇨ (x)->2*x
a/b; ⇨ a/b // ok
quote(a/b); ⇨ a/b (problem, not include quotation marks) ⇨
[up key][up key]copy '(a/b') error ? It's a BUG or not?
Is expected ⇨ quote(a/b) or 'a/b' or '(a/b)'
numer(quote((a/b))) ⇨ a/b
numer(eval(quote((a/b)))) ⇨ a // ok
[up][up]copy error ?
He does not let me retrieve the input
One of the functions of the history is to be able to call inputs and outputs and then manipulate them. Who agrees with this?
01-06-2017, 09:11 PM
RE: Possible BUG on History CAS
quote(a/b); ⇨ a/b
[up key][up key]copy ⇨ '( a/b' )
I think the problem is that the last expression is interpreted as a derivative diff(b),
-> diff( a/diff(b) )
The problem could be solved (copy input) if the expression has two ' at the beginning and end, are not derived is a single expression.
01-08-2017, 03:48 AM (This post was last modified: 01-08-2017 03:49 AM by Han.)
It is a bug (though only in Texbook entry mode)
Graph 3D | QPI | SolveSys
01-08-2017, 04:23 PM (This post was last modified: 01-14-2017 03:35 PM by compsystems.)
Some plans by HP-TEAM to correct this BUG?
