(12C) Sums of Σx, Σx^2, Σx^3
01-07-2017, 05:28 PM
(This post was last modified: 06-15-2017 01:14 PM by Gene.)
HP 12C: Sums of Σx, Σx^2, Σx^3
This program takes two arguments: Y: x X: n (where n=1, n=2, n=3) If n = 1, the sum Σ x from 1 to n is calculated If n = 2, the sum Σ x^2 from 1 to n is calculated If n = 3, the sum Σ x^3 from 1 to n is calculated If n is not 1, 2, or 3, an error occurs. Program: Keep in mind: this is done on the HP 12C (regular). For the HP 12C Platinum, the code for Last X is 43, 40 ([ g ] [ + ]) and the step numbers are three digits (000 instead of 00). STEP; KEY; CODE NUMBER 01; X<>Y; 34 02; STO 1; 44, 1 03; X<>Y; 34 04; STO 0; 44, 0 05; 1; 1 06; -; 30 07; X=0; 43,35 08; GTO 21; 44, 33, 21 09; RCL 0; 45, 0 10; 2; 2 11; -; 30 12; X=0; 43, 35 13; GTO 29; 44, 33, 29 14; RCL 0; 45, 0 15; 3; 3 16; -; 30 17; X=0; 43, 35 18; GTO 46; 43, 33, 46 19; 0; 0 20; ÷; 10 21; RCL 1; 45, 1 22; ENTER; 36 23; *; 20 24; LST X; 43, 36 25; +; 40 26; 2; 2 27; ÷; 10 28; GTO 00; 43, 33, 00 29; RCL 1; 45, 1 30; ENTER; 36 31; *; 20 32; LST X; 43, 36 33; X<>Y; 34 34; 3; 3 35; *; 20 36; +; 40 37; RCL 1; 45, 1 38; 3; 3 39; Y^X; 21 40; 2; 2 41; *; 20 42; +; 40 43; 6; 6 44; ÷; 10 45; GTO 00; 43, 33, 00 46; RCL 1; 45, 1 47; ENTER; 36 48; ENTER; 36 49; 1; 1 50; +; 40 51; *; 20 52; ENTER; 36 53; *; 20 54; 4; 4 55; ÷; 10 56; GTO 00; 43, 33, 00 Example: n = 5 Y: 5, X: 1. Result: 15 Y: 5, X: 2. Result: 55 Y: 5, X: 3. Result 225 |
