Halfnut HP 41CX repair help
01-16-2017, 05:37 AM (This post was last modified: 01-16-2017 02:19 PM by jay.)
I have two Halfnut HP 41CXs that both had corrosion on the I/O block and the I/O block connectors on the main PCB. I cleaned the corrosion, and managed to kind of get them working a bit before screwing the case halves back together by holding the cases together in just the right way, though some keys would be unresponsive if I didn't hold the cases together just right. The screw posts and wells look to be intact.
Now, after putting the screws back, neither calculator showed any life. I left the batteries out for a while, and then put them back in and pressed the ON button. I got the MEMORY LOST message, but it was either unresponsive to other keys or I would get strange behaviour from some keys - for example the MEMORY LOST message would shift in the display, or all the annunciators would light. I then removed and immediately replaced the batteries - the calculators showed no life. The behaviour of both units is quite similar.
Does anyone have any suggestions on what to try next?
Thanks
01-18-2017, 05:17 AM (This post was last modified: 01-18-2017 05:18 AM by jay.)
RE: Halfnut HP 41CX repair help
I turns out the I/O block flex PCBs were more damaged than I thought - I tested them with an I/O block from a good HP-41, and they both worked.
User(s) browsing this thread:
