Observatories
01-16-2017, 06:26 PM
Observatories
This program attempts to parse the observatories file from the Minor Planets Centre and map their locations.
But I'm not convinced by the map.
The map was done quickly, so I wouldn't be surprised to find it upside down (why is 0 at the top of computer screens???).
One complication with the original data is that latitudes are given as a composite value (lat*elevation), but I assume that will be a good enough approximation.
Eventually, I intend to incorporate this into my GEODATA program and/or an astronomical app.
If anyone who knows where the observatories are can indicate whether that map looks reasonable it would be appreciated - I was assuming it would look more like a world map...maybe my expectations were wrong, or do I have a bug in my handling of the coordinates.
Stephen Lewkowicz (G1CMZ)
01-16-2017, 06:28 PM
RE: Observatories
Version 0.001
 // OBSERVATORIES V0.001 2017 StephenG1CMZ
 LOCAL LF:=CHAR(10);
 LOCAL FS:=Notes("OBSERVATORIES.MPC");
 //CUSTOMISE
 LOCAL SHOWPROGRESS:=0;
 LOCAL LINES;
 LOCAL ZNAN;
 LOCAL OBSCODE,OBSFULLNAME;
 LOCAL OBSNUMI;
 LOCAL OBSCODES:={},OBSFULLNAMES:={};
 LOCAL OBSLNGS:={};
 LOCAL OBSLATS:={};
 LOCAL LINESPOS:={};
 LOCAL NUM1,NUM2,NUM3,NUM3SIGN;
 LOCAL LNGNUM;
 LOCAL LATCOS,LATSIN,LAT;
 IZWHITE(ST)
  LOCAL WHITESP:=" ";
  LOCAL POS:=1;
  IF DIM(ST)==0 THEN
  MSGBOX("EMPTY");
   RETURN 1;
  WHILE INSTRING(WHITESP,MID(ST,POS,1)) AND POS≤DIM(ST)  DO
   POS:=POS+1;
  RETURN (POS>DIM(ST)); //1=WHITESPACE ELSE 0
 PARSE_OBS(ALINE)
  OBSCODE:=MID(ALINE,1,4);
  IF SHOWPROGRESS THEN
   DRAWMENU(OBSCODE);
  //IF MID(OBSCODE,4)==" " THEN
  //ELSE
  // MSGBOX("BAD OBSCODE "+ASC(MID(OBSCODE,4)));
  // RECT_P();
  // END;
  //PRINT(ALINE);
  IF OBSCODE=="Code" THEN
   //HEADR LINE
  ELSE
   ZNAN:=0;
   NUM1:=(MID(ALINE,4,10));
   IF IZWHITE(NUM1) THEN
    //PRINT(".");
    NUM1:="0";ZNAN:=1; //NAN
    //DEBUG;
   LNGNUM:=EXPR(NUM1);
   IF ZNAN THEN
    LAT:=0;
   ELSE
    NUM2:=MID(ALINE,4+10,8);
    NUM3SIGN:=MID(ALINE,4+10+8,1);
    NUM3:=MID(ALINE,4+10+8+1,8);
    //LATCOS:=ACOS(EXPR(NUM2));
    LATCOS:=EXPR(NUM2);
    //PRINT(LATCOS);DEBUG;
    //PRINT(NUM3);
    LATSIN:=(180/π)*ASIN(EXPR(NUM3));
    //LAT:=(LATCOS+LATSIN)/2;
   IF NUM3SIGN=="-" THEN
    LATSIN:=−LATSIN;
   LAT:=LATSIN;
   OBSFULLNAME:=MID(ALINE,32-1);
   //PRINT(MID(ALINE,1,4)+" "+OBSNAME);
   OBSCODES(OBSNUMI):=OBSCODE;
   OBSFULLNAMES(OBSNUMI):=OBSFULLNAME;
   OBSLNGS(OBSNUMI):=LNGNUM;
   OBSLATS(OBSNUMI):=LAT;
   IF OBSCODE=="007 " AND 0 THEN
    MSGBOX("48-50= "+→HMS(LAT));
   OBSNUMI:=OBSNUMI+1;
 EXPORT READ_ALL_OBS(ST)
  LOCAL LFOFFSET,CH;
  LOCAL FRM,TOO;
  LOCAL TMP;
  LINESPOS:={0};
  LINES:=1; OBSNUMI:=1;
  IF SHOWPROGRESS OR 1 THEN
   DRAWMENU("Loading");
  REPEAT
   LFOFFSET:=INSTRING(MID(ST,LINESPOS(LINES)+1),LF);
   IF LFOFFSET THEN
    LINESPOS(LINES+1):=LINESPOS(LINES)+LFOFFSET;
    CH:= MID(ST,LINESPOS(LINES+1),1);
    IF CH==LF THEN
    ELSE
      MSGBOX("BAD LF"+CH);
    FRM:=LINESPOS(LINES)+1;
    TOO:=LINESPOS(LINES+1);
    PARSE_OBS(MID(ST,FRM,TOO-FRM));
    IF MID(ST,FRM,1)=="Z" AND 0 THEN
     PRINT("LINE"+LINES+"FRM"+FRM+"TO"+TOO);
     PRINT("CODE: "+MID(ST,FRM,4));
     PRINT(MID(ST,FRM,TOO-FRM));
    LINES:=LINES+1;
    //WAIT;
  UNTIL LFOFFSET==0;
  //DEBUG;
  //FINAL LINE IF LAST LF MISSING
  TOO:=SIZE(ST)-FRM;
  PARSE_OBS(MID(ST,FRM,TOO));
 //PRINT("SIZE "+SIZE(ST));
  //PRINT("Lines: "+LINES);
 QUICKPLOT()
  LOCAL II,XX,YY;
  RECT_P();
  //(NEEDS ":0-360=-180,180 ETC
  //MSGBOX(SIZE(OBSFULLNAMES));
  FOR II FROM 1  TO SIZE(OBSFULLNAMES) DO
   XX:=OBSLNGS(II);
   XX:=IFTE(XX>180,−(360-XX),XX);
   XX:=(320/360)*OBSLNGS(II);
   YY:=(240/180)*(OBSLATS(II)+90);
   RECT_P(XX,YY,XX,YY,RGB(255,0,0),RGB(99,99,99));
  DRAWMENU("DONE");
 VERY_INFO()
  WAIT;
  PRINT("Found "+SIZE(OBSCODES)+" Observatories");
 PROGRAMR_INFO()
 //USE FOR DISPLAY SIZING
  LOCAL II,ML,LONGNAME;
  PRINT("Longitudes:"+MIN(OBSLNGS)+".."+MAX(OBSLNGS));
  PRINT("Latitudes: "+MIN(OBSLATS)+".."+MAX(OBSLATS));
  ML:=0;
   IF DIM(OBSFULLNAMES(II))>ML THEN
    ML:=DIM(OBSFULLNAMES(II));
    LONGNAME:=OBSFULLNAMES(II);
  PRINT("LONGFULLNAME "+ML);
  PRINT(LONGNAME);
  WAIT;
  TEXTOUT_P(LONGNAME,0,200,3);//3 IS LARGEST FONT TO FIT NAME ON 1 LINE
 EXPORT OBS()
  LOCAL TBEG;
  PRINT();
  //MSGBOX(IZWHITE(" B   "));
  TBEG:=TICKS;
  READ_ALL_OBS(FS);
  TBEG:=TICKS-TBEG;
  PRINT((TBEG/1000)+" s");
  VERY_INFO();
  PROGRAMR_INFO();
  //MSGBOX("DONE");
  WAIT;
  QUICKPLOT();
  WAIT;
User(s) browsing this thread:
