Base conversion (including fractional parts)
01-27-2017, 05:02 AM (This post was last modified: 01-27-2017 12:24 PM by Han.)
Started by this thread: http://hpmuseum.org/forum/thread-7585-post-67381.html
Code below is from the aforementioned thread.
EXPORT basecalc()
  local maxdigits:=20; // maximum number of digits for frac part
  local j,k,t,run:=1;
  local b1:=10;
  local b2:=16;
  local d:=0;
  local n:="";
  local ds:="";
  local r:=string(rand,1,12); // create a random CAS variable
  local var:="";
  local ipn:=""; // integer part of n
  local fpn:=""; // frac part of n
  local digits:="0123456789ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz";
  k:=size(r)-2;
  var:="tmp" + right(r,k);
  while run do
    t:=input(
        { n, [2], { 15, 80, 0 } },
        { b1, [0], { 25, 25, 1 } },
        { b2, [0], { 70, 25, 1 } },
        { maxdigits, [0], {25,25, 2 } }
      "Base Converter",
      { "n=", "base1=", "base2=", "digits=" },
        "Enter the integer",
        "Enter the base of the integer n",
        "Enter the base to convert to",
        "Max allowable digits"
    if t then
      r:=var + ":={0,0}";
      CAS(EVAL(r));
      k:=size(n);
      if (k AND (b1 >= 2) AND (b2 <= 62)) then
        j:=instring(n,".");
        if j then
          if (j-1>0) then ipn:=left(n,j-1); end;
          if (k-j>0) then fpn:=right(n,k-j); end;
          k:=j-2;
        else
          ipn:=n;
          k:=size(n)-1;
        end;
        // k = largest exponent
        t:=size(ipn);
        for j from 1 to t do
          ds:=mid(ipn,j,1);
          d:=instring(digits,ds)-1;
          if ((d >= b1) OR (d < 0)) then msgbox("Invalid digit: " + ds); j:=-1; break; end;
          r:=var + "[1]:=" + var + "[1]+" + d + "*" + b1 + "^" + k;
          k:=k-1;
          CAS(EVAL(r));
        end;
        if (j == -1) then continue; end;
        t:=size(fpn);
          ds:=mid(fpn,j,1);
          r:=var + "[2]:=" + var + "[2]+" + d + "*" + b1 + "^" + k;
          k:=k-1;
          CAS(EVAL(r));
        end;
        n:="";
        t:=size(ipn);
        if t then
          r:="ip(ln(" + var + "[1])/ln(" + b2 + ")))";
          k:=CAS(EVAL(r));
          for j from k downto 0 do
            r:="ip(" + var + "[1]/(" + b2 + "^" + j + "))";
            d:=CAS(EVAL(r));
            ds:=mid(digits,d+1,1);
            n:=n+ds;
            r:=var + "[1]:=" + var + "[1] - " + d + "*" + b2 + "^" + j;
            CAS(EVAL(r));
          end;
        end;
        t:=size(fpn);
        if t then
          n:=n+".";
          r:="numer(" + var + "[2])"; t:=CAS(EVAL(r));
          r:="denom(" + var + "[2])"; k:=CAS(EVAL(r));
          for j from 1 to maxdigits do
            r:="ip(" + var + "[2]*" + b2 + ")";
            d:=CAS(EVAL(r));
            r:=var + "[2]:=" + var + "[2]*" + b2 + "-" + d;
            CAS(EVAL(r));
            // floating point issue
            r:=var + "[2] < 0";
            if CAS(EVAL(r)) then
              r:=var + "[2]:=" + var + "[2]+1";
              CAS(EVAL(r));
              d:=d-1;
            end;
            n:=n+ds;
            r:=var + "[2] == 0";
            if CAS(EVAL(r)) then break; end;
          end;
        end;
        t:=b1;
        b1:=b2;
        b2:=t;
      else
        msgbox("Invalid input");
      end;
    else
      run:=0;
    end;
  end;
  r:="purge(" + var + ")";
  CAS(EVAL(r));
  return(0);
Graph 3D | QPI | SolveSys
01-27-2017, 08:57 PM
RE: Base conversion (including fractional parts)
Radix, Very good program
an idea
To start choosing the style
1: single [input / output] field (current)
2: two separate [input] / [output] fields, To view or compare conversion
3: an option with text (bases more known or useful)
BINARY 2
OCTAL 8
DECIMAL 10
DUDECIMAL 12
HEXADECIMAL 16
VIGECIMAL 20
SEXAGECIMAL 60
https://en.wikipedia.org/wiki/Radix
4: separate in the case of hexadecimal numbers the outputs in pairs for easier reading
FF 8F 0F
5: lowercase support ff8f0f
01-27-2017, 10:19 PM
(01-27-2017 08:57 PM)compsystems Wrote:  Radix, Very good program
I was not able to find a program named Radix in the HP Prime software library. Do you have a link?
BINARY 2
OCTAL 8
DECIMAL 10
DUDECIMAL 12
HEXADECIMAL 16
VIGECIMAL 20
SEXAGECIMAL 60
FF 8F 0F
I will leave these ideas for others to implement. I usually hate doing UI design :-)
Quote:5: lowercase support ff8f0f
Lower case letters are actually used as digits for bases 37 through 62, so this would cause a conflict if we were to use lower case letters as alternatives to capital letters. I suppose that we could allow for lower case letters for digits only in the cases where the base is 36 or less. A simple test of the base, along with a conversion to upper case would be more than sufficient. But again, this is a "UI" option I'll leave to folks who are not as lazy as myself. :-)
01-28-2017, 03:57 AM
Radix synonymous of base =)
Base conversion is a port of BASECAL (rpn)? As a suggestion to separate the hp-prime code in sub-functions
PHP Code:
%%HPT(3)A(R)F(.);
IB  Take either a binary or a real from the stack and return
it in the base specified in BBASErounded off to IBFIX
@        places.
IB->  : Take an IB string from the stack and convert it to either
@        a binary number or a real.  If IBFIX is set to zeroit will
@        always return a binary number.  If IBFIX is set to somthing
@        other than zeroit will use return a real if the base-10
@        numver is less than 1E12.
IB2-> : Runs IB-> on the objects in level one and twoleaving their
@        order intact.
BBASE The current base. (2-62 is valid)
IBFIX Number of desired decimal places. (0 will force all calculations
@                                          to be carried out in binaries)
IB2 Runs ->IB on the objects in level 1 and twoleaving their
@        order intact.
BASECALC by Ian Matthew Smith
Automatic decimal lengths added by Joe Horn
DIR
  BMTH
create custom menu
\<< { Add \<< IB2\-> + \->IB \>> }
Sub \<< IB2\-> - \->IB \>> }
Mul \<< IB2\-> * \->IB \>> }
Div \<< IB2\-> / \->IB \>> }
BBASE "/" IBFIX + +
B\->FIX 'BBASE' STO BMTH \>>
B\->FIX SWAP IB\-> SWAP 'BBASE' STO \->IB BMTH \>>
'IBFIX' STO BMTH \>> }
\->LIST CONV {
DUP
IF TYPE 2 ==
THEN IB\->
ELSE \->IB
        END
DUP
IF TYPE 0 ==
THEN R\->B
ELSE DUP
IF TYPE 10 ==
THEN B\->R
          END
        END
\>> } } \->LIST TMENU
IB
\<< DUP
IF TYPE 0 ==
THEN DUP FP SWAP IP R\->B
ELSE 0 SWAP
      END DUP
IF TYPE 10 ==
THEN RCWS SWAP "" SWAP 64 STWS
WHILE DUP B\->R
        REPEAT DUP BBASE DUP2
/ * - BSTR SWAP
          B
\->R DUP SUB ROT SWAP BBASE /
END DROP SWAP STWS SWAP
IF DUP BBASE IBFIX ^ * <
THEN DROP
ELSE "" SWAP 1 IBFIX
          START
IF DUP 0 \=/
THEN BBASE DUP IP BSTR SWAP 1 DUP SUB ROT SWAP SWAP FP
            END
          NEXT DROP
"." SWAP + +
END
      END
IB\->
DUP
IF TYPE 2 ==
THEN RCWS SWAP 64 STWS
IF DUP "." POS
        THEN DUP DUP
"." POS SWAP DUP SIZE ROT 1 SWAP SUB
          SWAP DUP
"." POS 1 1 SWAP SUB
ELSE "" SWAP
        END
# 0d SWAP DUP SIZE 1 - 0 SWAP
FOR j DUP DUP SIZE j DUP SUB BSTR SWAP POS 1 # 1d
IF j 0 >
THEN BBASE 1 j
            START DUP ROT
SWAP
            NEXT DROP
          END
ROT SWAP
        NEXT DROP
IF DUP B\->R 1.E12 IBFIX AND
THEN B\->R
        END SWAP
IF DUP SIZE
        THEN 0 SWAP DUP SIZE 1 SWAP
FOR j DUP j j SUB BSTR SWAP POS 1 BBASE j NEG ^ * ROT SWAP
          NEXT DROP
        ELSE
DROP
        END SWAP STWS
ELSE
        IF
DUP TYPE 0 == IBFIX NOT AND
THEN R\->B
        END
      END
IB2\->
IB\-> SWAP IB\-> SWAP
BBASE 16
  IBFIX 0
\->IB2
\<< \->IB SWAP \->IB SWAP
B\->FIX  this tiny routine was tacked on by Joe Horn
\<< 2 MAX 62 MIN 12 OVER LOG IP 'IBFIX' STO
BSTR
END
01-28-2017, 03:40 PM
(01-28-2017 03:57 AM)compsystems Wrote:  Base conversion is a port of BASECAL (rpn)?
No, I just wrote the program based on my own understanding of base conversions and what Joe was requesting.
01-29-2017, 12:29 PM
What utility have the conversion of real numbers between different bases? I have only used conversion between integers.
About the program, please separate the UI from the functions, to create custom UI
