Graphing Differential Equations (Slope Fields)
01-27-2017, 05:10 AM
(This post was last modified: 01-27-2017 07:15 AM by CloudHP.)
I'm currently using my HP Prime's geometry app CAS plotfield() function to graph my slope fields, however the lines are a bit longer than how I want. Is there any way to make the tangent lines shorter?
I want it to be something similar to this: ![]() Currently, mine looks like this: https://drive.google.com/file/d/1ef9Zmfi...sp=sharing |
01-27-2017, 06:06 PM
RE: Graphing Differential Equations (Slope Fields)
(01-27-2017 05:10 AM)CloudHP Wrote: https://drive.google.com/file/d/1ef9Zmfi...sp=sharing Hello, Are you manually typing in a 'plotfield' command? Or using the little popup editor that appears when you press the Plot->slopefield in your plot view? If you don't see a little editor when you do that, that means you aren't up to date in your Prime software. I ask because the editor screen automatically adds in the required 'normalize' tag at the end to give you what you'd like here. plotfield(sin(x),[x = ((-16.) .. 16.),y = ((-11.) .. 10.9)],xstep = 2.5,ystep = 2.5,'normalize') <-- note the 'normalize' as the last argument. TW Although I work for HP, the views and opinions I post here are my own. |
01-27-2017, 10:17 PM
(This post was last modified: 01-28-2017 01:08 AM by CloudHP.)
(01-27-2017 06:06 PM)Tim Wessman Wrote:(01-27-2017 05:10 AM)CloudHP Wrote: https://drive.google.com/file/d/1ef9Zmfi...sp=sharing I am going into the commands in the CAS Geometry, hitting plot and then hitting slopefield. Does this mean my software is out of date? I just plugged it in recently and it said I had software updates so I updated. I can use the normalize function which just types normalize() into the equation. How would I use it in correlation to the plotfield function? Also sorry, could you explain a brief tutorial on how to graph slope fields in general? What do the vector variables mean? I am a bit confused. Thanks. |
01-28-2017, 01:15 PM
Did you read the user guide? It explains how to produce the slope field you want in Chapter 9, Geometry App, specifically page 162, in the latest edition.
01-29-2017, 06:42 AM
RE: Graphing Differential Equations (Slope Fields) | |||
