WTB: HP-65 AC adapter
01-29-2017, 01:42 AM
I think I goofed mine by trying to charge a battery pack that was not making contact with the springs.
01-29-2017, 02:33 AM
RE: WTB: HP-65 AC adapter
I would not have thought that a classic charger would care if the battery pack was making contact or not. What I have seen happen to these chargers is wires break in the cable. Does the 65 still work? The classic charger provides a separate regulated +5v to run the calculator when it is plugged in and also an unregulated voltage that charges the battery. Do you have a meter that you could check the voltage at the end of the charger cord?
Paul. |
01-29-2017, 02:47 AM
(01-29-2017 02:33 AM)Paul Berger (Canada) Wrote: I would not have thought that a classic charger would care if the battery pack was making contact or not. What I have seen happen to these chargers is wires break in the cable. Does the 65 still work? The classic charger provides a separate regulated +5v to run the calculator when it is plugged in and also an unregulated voltage that charges the battery. Do you have a meter that you could check the voltage at the end of the charger cord?Thanks Paul. No, I don't have a meter. The 65 still works. In fact, I have two 65's and both of them work, they just won't work when the charging cable is plugged in and a batt pack is present. And they used to work when the cable was plugged in to charge the battery. But I suspect the AC adapter was damaged when I went to charge one of the 65 batt packs for 12 hours and the batt pack was not making contact with the prongs in the batt compartment of the 65. I think that must have damaged the AC cable somehow, because the LED on the separate charger does not light up, so I think the AC adapter is faulty. That's why I am looking for a new one. Don |
01-29-2017, 03:05 AM
(01-29-2017 01:42 AM)Don Shepherd Wrote: I think I goofed mine by trying to charge a battery pack that was not making contact with the springs. Don - Here is another option on TAS, a cable for charging HP's classic model machines, powered from USB port. These definitely do work, I have one. They used to be cheaper, but now are priced at $45, so not much better than adapter. Just a thought. --Bob Prosperi |
01-29-2017, 03:50 AM
(01-29-2017 03:05 AM)rprosperi Wrote:(01-29-2017 01:42 AM)Don Shepherd Wrote: I think I goofed mine by trying to charge a battery pack that was not making contact with the springs. Thanks Bob, I didn't know about that. If I don't get any responses here for the old HP adapter, I may go that route. I suppose that would use the same USB wall adapter as my Kindle Fire or Nexus 7 USB chargers. |
01-29-2017, 05:55 AM
(01-29-2017 02:47 AM)Don Shepherd Wrote:(01-29-2017 02:33 AM)Paul Berger (Canada) Wrote: I would not have thought that a classic charger would care if the battery pack was making contact or not. What I have seen happen to these chargers is wires break in the cable. Does the 65 still work? The classic charger provides a separate regulated +5v to run the calculator when it is plugged in and also an unregulated voltage that charges the battery. Do you have a meter that you could check the voltage at the end of the charger cord?Thanks Paul. No, I don't have a meter. The 65 still works. In fact, I have two 65's and both of them work, they just won't work when the charging cable is plugged in and a batt pack is present. And they used to work when the cable was plugged in to charge the battery. But I suspect the AC adapter was damaged when I went to charge one of the 65 batt packs for 12 hours and the batt pack was not making contact with the prongs in the batt compartment of the 65. I think that must have damaged the AC cable somehow, because the LED on the separate charger does not light up, so I think the AC adapter is faulty. That's why I am looking for a new one. If it does not work with the charger plugged in that would suggest that the +5V on the charger cable is missing. When you plug the charger into the calculator there is a metal leaf in the socket that gets pushed away from the pins in the connector disconnecting the battery from the the electronics, so if there is no +5V from the charger the calculator will not operate. One thing that just occurred to me is one version of the charger has a switch to select 110V or 220V input if switched to the 220V position and you plug it into 110V the output may be too low to operate the calculator. |
01-29-2017, 02:57 PM
(01-29-2017 05:55 AM)Paul Berger (Canada) Wrote:(01-29-2017 02:47 AM)Don Shepherd Wrote: Thanks Paul. No, I don't have a meter. The 65 still works. In fact, I have two 65's and both of them work, they just won't work when the charging cable is plugged in and a batt pack is present. And they used to work when the cable was plugged in to charge the battery. But I suspect the AC adapter was damaged when I went to charge one of the 65 batt packs for 12 hours and the batt pack was not making contact with the prongs in the batt compartment of the 65. I think that must have damaged the AC cable somehow, because the LED on the separate charger does not light up, so I think the AC adapter is faulty. That's why I am looking for a new one. It could be that there was a break in the cable, but it is not obvious from looking at the cable, and I don't have equipment to detect that. Yes, my adapter does have the 110/220 switch, which has always been set to 110 of course (I presume 220 is for Europe). I may try that USB cable Bob mentioned above, that's probably the best choice now. |
01-29-2017, 11:53 PM
(01-29-2017 09:13 PM)Geir Isene Wrote: I think I have a few of these. I could go check in my stock of things. I don't want money - do you have anything interesting to trade? Thanks Geir. Another member is loaning me an AC adapter he knows works, along with the USB adapter mentioned above, so I can troubleshoot a bit and see if my adapter is really faulty. If it is, I'll probably just get the USB adapter, mentioned above in the thread. I'm afraid I have very little to trade. I purged my HP collection a few years ago and the only thing I have left are 2 12c's, 2 17b's, 2 17bii's, and 2 65's. I enjoy programming all of those in my olden age. Don |
02-02-2017, 10:37 PM
Thanks to all for comments. I got one of the USB cables that Bob Prosperi mentioned above, and it seems to work fine. I can confirm that my HP-65 AC adapter was faulty.
By the way, the USB cable 3 hole plug won't fit in the separate standalone charger for Classics unless you trim back some of the plastic around the charger housing. |
