Basic Question
01-30-2017, 08:14 AM
Basic Question
If I wanted to find the roots and intersections between other graphs of the ellipse (4x^2 + y^2 = 1 for example), which app would I use to find the answers most easily?
Function doesn't let you enter y in symbolic view. Advanced Graphing doesn't have the function tools that function has. Geometry doesn't either. Sorry for the basic question, but thanks for the help! |
01-30-2017, 12:35 PM
RE: Basic Question
(01-30-2017 08:14 AM)CloudHP Wrote: If I wanted to find the roots and intersections between other graphs of the ellipse (4x^2 + y^2 = 1 for example), which app would I use to find the answers most easily? Use the Function app for actual functions (i.e. ones that can be defined in the form f(x)=blah). For everything else, use the Advanced Graphing function. In your case, since you want to use the tools that Function has, then you would probably need to convert 4X^2+Y^2=1 into two parts: Y=SQRT(1-4X^2) and Y=-SQRT(1-4X^2). The equation, in its original form, does not actually define a function. Graph 3D | QPI | SolveSys |
01-31-2017, 03:10 AM
RE: Basic Question
Oh okay, so I would need to convert it into a y = ... form to use the function capabilities.
01-31-2017, 10:30 AM
RE: Basic Question | |||
