HP vers.11226
01-31-2017, 08:45 AM
HP vers.11226
HI,
Here are the differents dimensions I obtain on my PC win10.
The olds versions up to 10638 are biggers than version 11226.
Am-I alone to get this ? Is-it normal ?
Gérard.
01-31-2017, 10:33 AM (This post was last modified: 01-31-2017 10:51 AM by ggauny@live.fr.)
RE: HP vers.11226
HI,
Another thing I see comparing 10638 and new version 11226 :
for the same program beginnig at the same time, version 11226 keep the picture on screen 5 minutes and the version 10638 keep the picture on the screen until I volontary press the escape key ?
Have a look on attachements please.
May I have an explication at the two thread ?
Thanks.
Gérard.
02-01-2017, 07:01 AM
RE: HP vers.11226
It's the auto off which is turning the calculator screen off.
A side effect of turning the calc off is that all the data files are being saved when you do so.
Cyrille
02-01-2017, 11:13 AM (This post was last modified: 02-01-2017 11:14 AM by ggauny@live.fr.)
RE: HP vers.11226
Thanks for the answer,
So in the version 10638 there is no auto off, because the picture on screen stay always.
Why have-I two size of virtual prime on the PC ? Is-it because in 10638 pictures are in .bmp format and in 11226 in .png format ?
Thank for explain to me because the medium format.png from 11226 version appear very little to work, you have see the difference in my attachement.
Gérard.
