[SOLVED] Issue with cZeros
02-05-2017, 11:06 AM
(This post was last modified: 02-05-2017 12:06 PM by tiamattia.)
I'm developing a program to design filters using Butterworth and Chebyshev type I. To do this i defined some cas function to solve equations or denormalize things. Some of these functions are: Code:
BP_Denorm_TF works right also inside of a program. Instead, BP_Denorm_Zeros is not working as it should inside of a program. If i call this function directly from cas, everything works, the result is two zeros in the origin. If i call this function inside of a program, no solutions are returned. What's the problem? |
02-05-2017, 11:31 AM
RE: Issue with cZeros
Problem solved, when using CAS commands in program mode, you have to provide the variable to solve. I think it's because in program mode the default var is X while in CAS is x. (I'm usign x)
