Can't make format() work
02-19-2017, 10:17 PM
In examples I've seen
format(9.3456,"s3") should show 9.35 in algebraic mode but All I get is syntax error. Since format is in lower case, I also tried CAS.format(9.3456,"s3") with the same result. How do you use the format function? Also, how do I set fixed decimal mode from an HPPL program? Tom L Tom L Cui bono? |
02-19-2017, 11:57 PM
RE: Can't make format() work
It needs CAS(format(9.3456,"s3")), not CAS.format.
Just checked and its still OK on the new release on Android. http://www.hpmuseum.org/forum/thread-647...ght=format Stephen Lewkowicz (G1CMZ) |
02-20-2017, 02:11 AM
(02-19-2017 11:57 PM)StephenG1CMZ Wrote: It needs CAS(format(9.3456,"s3")), not CAS.format. Boy am I getting old! I even replied to that thread! :0 Tom L Tom L Cui bono? |
