41Z Routine of the week: DFT
02-22-2017, 01:54 PM (This post was last modified: 02-22-2017 08:24 PM by Ángel Martin.)
Discrete Fourier Transform with the 41Z Module.
Not much of a groundbreaking algorithm, the program below uses the straightforward definition to obtain the DFT and inverse DFT of a set of N complex data points, stored in complex data registers ZR01 to ZR0n. You can use the sub-function ZINPT from the module to enter all values.
Just enter the sample size in X, and execute ZDFT. The results are stored in complex registers ZRn+1 to ZR(2n). You can use the sub-function ZOUPT to see the values.
If you want to apply the inverse DFT to the results you can use REGSWAP to reset the locations: 2,00(2+2n)00(2n). i.e. 2,010|008 for n=4. Then run ZIDFT to obtain the original values (except rounding).
Example:
DFT [ 1+2i ; 3+4i ; 5+6i ; 7+8i ] = [ 16+20.i ; -8 ; -4-4.i ; -8.i ]
IDFT [ 16+20.i ; -8 ; -4-4.i ; -8.i ] = [ 1+2i ; 3+4i ; 5+6i ; 7+8i ]
01   LBL "ZDFT"
02   CF 01
03   GTO 02
04   LBL "ZIDFT"
05   SF 01
06   LBL 02
07   STO N
08   E3/E+
09   STO M
10   LBL 01
11   VIEW M
12   CLX
13   STO 00
14   STO 01
15   RCL N
16   E3/E+
17   STO O
18   RCL M
19   INT
20   E
21   -
22   PI
23   *
24   ST+ X
25   RCL N
26   /
27   STO P
28   LBL 00
29   RCL O
30   INT
31   E
32   -
33   RCL P
34   *
35   FC? 01
36   CHS
37   1
38   P-R
39   ZRC* IND O
40   ZST+ 00
41   ISG O
42   GTO 00
43   RCL M
44   INT
45   RCL N
46   +
47   ZRCL 00
48   FC? 01
40   GTO 02
41   RCL N
42   ST/ Z
43   /
44   LBL 02
45   ZSTO IND Z
46   ISG M
47   GTO 01
48   END
As always, the execution time can be rather long for large size samples. Using the 41-CL or an emulator in Turbo mode is recommended.
Feedback is welcome - would be great to get an FFT implementation as well... any volunteers?
03-01-2017, 08:26 AM
RE: 41Z Routine of the week: DFT
'Angel,
I am having a problem executing this program... specifically steps 27 thru 33. You use the P register for storage at step 27, then enter E at step 31. I think this blows part of the P register, so your recall at step 33 won't work properly, or do I understand your use of E as a step properly? I am thinking you are using E as a faster "1" entry.
Greg.
03-01-2017, 05:05 PM (This post was last modified: 08-11-2017 05:09 AM by Ángel Martin.)
Good catch Greg, thanks for the warning. Indeed using "E" is not a good idea if register P is also used for storage, I had completely forgotten about that... since I moved to the all-MCODE version in the updated module attached ;-)
So just change the "E" to a "1" and the program should work fine.
Here's an alternative FOCAL version that should always work, just to close this issue. It does the intermediate multiplication in-situ so registers R00 and R01 are free to use now.
01    LBL "ZDFT"
02    CF 01
03    GTO 00
04    LBL "ZIDFT"
05    SF 01
06    LBL 00
07    STO 00
08    E3/E+
09    STO M(5)
10    LBL 01
11    VIEW M(5)
12    RCL 00
13    STO N(6)
14    E3/3+
15    STO O(7)
16    RCL 5(M)
17    INT
18    ST+  N(6)
19    E
20    -
21    PI
22    *
23    ST+ X(3)
24    RCL 00
25     /
26    STO 01
27    CLZ
28    ZSTO IND N(6)
29    LBL 02
30    RCL 0(7)
31    INT
32    E
33    -
34    RCL 01
35    *
36    FC? 01
37    CHS
38    E
39    P-R
40    ZRC* IND O(7)
41    ZST+  IND N(6)
42    ISG O(7)
43    GTO 02
44    FC? 01
45    GTO 00
46    ZRCL IND 01
47    RCL 00
48    ST/ Z
49     /
50    ZSTO IND 01
51    LBL 00
52    ISG M(5)
53    GTO 01
54    END
Latest revision of the 41Z deluxe is attached.
Cheers,
Ángel
