IFTE CMD & IFT new CMD
02-26-2017, 03:53 PM (This post was last modified: 02-26-2017 04:53 PM by compsystems.)
HELLO
I'm trying to port a code, to replace IF THEN ELSE END, by IFTE
1: in many cases you must enclose the field to true and false between (), when you try it in history view
fail
PHP Code:
iftetype(expr2) <> DOM_SYMBOLIC partn:=string(expr2), partn:=conv2RPN3(expr2) );
ok
PHP Code:
iftetype(expr2) <> DOM_SYMBOLIC , ( partn:=string(expr2) ), ( partn:=conv2RPN3(expr2) ) );
Original Code
PHP Code:
#cas
conv2RPN2(expr1):=
begin
  local rpnStr
operpartnpartspartJexpr2;
rpnStr:="";
oper:="";
partn:="";
  if (
type(expr1) <> DOM_SYMBOLICthen
    rpnStr
:=string(expr1);
    return(
rpnStr);
end;
oper:=part(expr1,0);
parts:=part(expr1);
  for
partJ from 1 to parts do
expr2:=part(expr1,partJ);
    if (
type(expr2) <> DOM_SYMBOLICthen
      partn
:=string(expr2);
    else
partn:=conv2RPN2(expr2);
end;
    if (
partJ 1then rpnStr:=rpnStr " "end;
rpnStr:=rpnStr partn;
    if ((
partJ 1) or (parts == 1)) then
      rpnStr
:=rpnStr " " oper;
end;
end;
  return(
rpnStr);
end;
#end
PHP Code:
// convToRPN3(x^3);
#cas
convToRPN3(expr1):=
begin
  local rpnStr
rpnStr:="";
oper:="";
partn:="";
iftetype(expr1) <> DOM_SYMBOLIC, [ rpnStr:=string(expr1), return(rpnStr) ] );
parts:=part(expr1);
  for
iftepartJ , ( rpnStr:=rpnStr " " ), "" );
    if ((
      rpnStr
:=rpnStr " " oper;
end;
end;
  return(
rpnStr);
end;
#end
2: A new IFT command is required, on a future firmware
The field for the false condition, I put an empty string, but this is rubbish and when running in the history view it looks bad
PHP Code:
PHP Code:
iftpartJ , ( rpnStr:=rpnStr " " ) );
3: Now if the field of true or false have more than one statement the compiler generates an error, how to solve this?, I try to group sentences between [], but fails =(
PHP Code:
iftetype(expr1) <> DOM_SYMBOLIC, [ rpnStr:=string(expr1), return(rpnStr) ], "" );
All of the above for the purpose of running a CAS program step by step, placing each instruction in the history view
