SHARP EL-5120 Programmable Scientific Calculator: SOLVER machine with ENTER key?
03-05-2017, 03:01 PM
(This post was last modified: 03-05-2017 03:15 PM by jebem.)
Compact, well built, direct algebraic logic calculator, with a handy uncommon 3 lines alphanumeric characters with very high contrast black LCD display, from 1994.
Obviously the SOLVER capacity is the main feature of the model complemented by its programming ability. I didn't spend my time checking it in detail, but here are some highlights taken from the manual: Powered by a single CR-2025 battery cell. 3mW power consumption at 3VDC. Contrast adjust by software. Display: 14 characters and 2 exponents x 3 rows, 5x5 dot matrix. Number of display digits: 10 mantissa + 2 exponent Number of internal calculation digits: 12 mantissa Variables:
Memory manager shows free memory. Memory is shared between Variables, Programs and Equations. Each variable consumes 8Byte (where its name takes 1Byte). Each new Program structure takes 32 Byte; each line takes 3Byte plus the number of characters (1Byte each) or commands (1Byte each). Setup allows to chose Deg, Rad, Grad, Floating, Fixed, Scientific, Engineering, Fractions. It has four Operation Modes:
It supports three ways to calculate an unknown variable concerning its SOLVER calculation methods:
Packaging and documentation. Forensic test result: 8.99998762105 Compact pocket calculator. Jose Mesquita RadioMuseum.org member |
03-05-2017, 03:14 PM
SHARP EL-5120 Programmable Scientific Calculator: SOLVER machine with a ENTER key?
Tear down.
Removing the back cover just requires to undo 8 screws and a plastic pry tool. Nothing fancy to see here. The SoC is unknown and covered with black epoxy. The back cover features a glued metallized paper shielding. Jose Mesquita RadioMuseum.org member |
03-06-2017, 03:24 PM
RE: SHARP EL-5120 Programmable Scientific Calculator: SOLVER machine with ENTER key?
I like the display, but I miss the indirect addressing capability, considering the RAM size.
Calculator Benchmark |
03-07-2017, 11:24 AM
(03-06-2017 03:24 PM)xerxes Wrote: I like the display, but I miss the indirect addressing capability, considering the RAM size. Yap, and it looks like a lot of RAM (for a calculator from that era), but my guess is that it can be consumed easily fast with not so many objects, especially when creating programs. Additionally it doesn't include direct support for complex numbers, something that is important to have for EE for instance. Still a nice calculator imho. Jose Mesquita RadioMuseum.org member |
