Help needed reviving a 30b
03-15-2017, 09:11 AM
(This post was last modified: 03-15-2017 09:45 PM by Christobaldo.)
Hi all,
I tried flashing a 30b to a WP-31S using the procedure described in this post : http://www.hpmuseum.org/forum/thread-715...hlight=34S I guess i made an error using an arduino uno (5V RX/TX signal). Now my 30b seemed bricked : it doesn't switch on. Is it bricked ? Can i flash it to WP-31S ? Is there a way to revive it ? |
03-16-2017, 02:43 AM
RE: Help needed reviving a 30b
Sadly, I think you now have a doorstop with buttons. I'd have to search for the post, but I do recall a warning that the calculator CPU will be damaged by a 5V applied signal, or a voltage on any pin that is more than about half a volt above the positive supply.
A number of programming schematics show a series resistor on the program lines so that a current flowing through the resistor will create a voltage drop to a safe level at the chip end. That arrangement is recommended if you power the calculator from internal batteries, so you won't run afoul of the second condition above when using 3.3V logic signals in combination with low batteries. Somewhere I downloaded such a diagram from a post on this site. Sorry to be the bearer of bad news Remember kids, "In a democracy, you get the government you deserve." |
03-16-2017, 09:22 AM
So i'll have a brick .... or replacement parts for my WP-34S and my future WP-31S !!
I am gonna try again with another 30b. I'll be more attentive to protection and voltage :-) . If anybody needs part from a bricked 30b, contact me ! |
