IDEA: clear a-z cmd
03-21-2017, 03:01 PM
(This post was last modified: 03-22-2017 09:31 PM by compsystems.)
IDEA: clear a-z cmd
Hello sorry for my bad english
One of the problems for students, when a calculator as HP-PRIME or TI-89 stores a-z user variables, is that if one does not delete the variables, the results are evaluated, without showing the general or symbolic solutions. See publication in the following link http://courses.wccnet.edu/~palay/math179/intslv92.htm The TI68k have an option to remove the symbolic variables a-z, I think it would be a good option to incorporate it into the HP-PRIME for cas MODE, The RESTART CMD works but deletes all definitions =(, then a single command is required for the alphabetic variables, or expand RESTART CMD, accepting arguments RESTART([arg]) RESTART( "ALL" ); RESTART( "a-z" ); ![]() ![]() ![]() ![]() ![]() CAS VIEW PHP Code: CAS VIEW HOME VIEW PHP Code: HOME VIEW |
03-21-2017, 08:33 PM
RE: IDEA: clear a-z cmd
Is √(y^2*z+5*y*z+4)+2)/y different from √(598)+2)/6) with y=6 and z=9? No, so the result is correct.
So one has to be aware of the variables one has used before and then gets the desired symbolic results. I myself usually nearly never assign values to variables used in cas and have some rules I follow when I do so. Nevertheless the idea of spending purge some more parameters is not bad. Arno |
03-22-2017, 05:48 AM
One of the issue here is the meaning of the word "variable". In symbolic math, a variable is a name used in replacement of an unknown value. In the symbolic word, a variable does not have any value (at least most of the time). In lower grade math, in "computational" math, in physics or in programming worlds, a variable is a named container for a value. a Variable always has a value which it temporary replaces for clarity, readability or to allow a series of final computations with various values for the said variables. Prime does have both these worlds in it. Home is definitely computational math. Cas is symbolic. But the 2 also interact to add to the confusion ![]() The end result is Prime. Power and flexibility, but at the cost of the need to understand such subtility. In your case, remember that by default, A-Z variables always have a value (computational) and a-z (lowercase) do not (symbolic). And you should be OK. Hope this helps. Cyrille Although I work for the HP calculator group, the views and opinions I post here are my own. I do not speak for HP. |
03-22-2017, 03:03 PM
That is fine for FORTRAN programmers that can use I for a loop variable, but what about us C programmers that have to use i? 8^)
I suggest that the OP write his own darn function/program if it is that important to him. |
03-22-2017, 06:42 PM
(This post was last modified: 03-22-2017 09:30 PM by compsystems.)
The SOLVE in capital letters is not documented in the CATALOG HELP
Quote:solve Quote:SOLVE I do not understand the last part [0 - 3] Update the examples of the first post, I think that THE DIFFERENT CASES should have a more detailed explanation by Bernard |
03-23-2017, 04:52 PM
solve(equation) solves equation with respect to x
solve(equation,var) solves equation with respect to var solve([eq1,eq2,..],[var1,var2,...]) solve polynomial system with respect to var1,var2,... The last syntaxes call the numeric solver, using an iterative method (var=guess) or bisection (var=a..b). |
03-24-2017, 08:21 PM
SOLVE CMD in capitals should not evaluate after solving, when the variables are also capitals, because by default X, Y, ... are initialized to zero and there is no way to eliminate previously.
Please check the examples above Thank you |
