HP71b HPIL/HPIB devices
03-25-2017, 09:11 PM
Hello
for some time I have randomly collected various old HPIB equipment that was thrown out in various locations that I would like to connect to my HP71b.
I do have a HP-IL/HP-IB interface 82169A connected to my HP71b
But I cant seem to get it to work
I have a Thinkjet 2225A HPIB printer and a HP9122S HPIB disk drive
I never worked with HPIB so I am not familiar with how it works, I do know that I need to set the address jumpers on the back and I set "1" on both units, I only connect one at the time to the 82169A for the moment.
I have tried to read both the HPIL manual and the 82169A manual but I cant understand how to interface them with each other.
If I do
RESTORE IO
it passes so communication with 82169A is good
but If I do
PRINTER IS :PRINTER
I get:
HPIL ERR:Device not found
But as I understand it this command is for the HPIL printer and not the HPIB
I think I need to initialize the printer in some way so that the 82169A knows what address the printer is on but I cant seem to find how to
the same with the HP9122S no luck at all
I might be missing some information how to do this, I have tried to read all manuals I could find about the subject but as I said, I have never worked with HPIB or HPIL
It would be nice to be able to save data from my HP71b on a diskette and to be able to print stuff and perhaps connect it to my oscilloscope and multimeter and various instruments.
I do actually have two HP71b with HPIL interfaces, is it possible to transfer data between these units with the HPIL interface?
10C,11C,12C,15C,16C,21,25,25C,34C,35,45,41CV,41CX,71B,97,32S,35S,42S
03-25-2017, 09:56 PM
RE: HP71b HPIL/HPIB devices
Assuming you only have the HP-82169A on the HP-IL loop
and the HP-2225A on the HP-IB interface.
HP-82169A dip switch setting should be (from left to right) "0 0 0 0 0 1"
Leftmost digit: 0 = Translator / 1 = Mailbox -> here 0
Next 5 digits: address (0..31) -> here 00001 = 1
HP-2225A -> Dip switch 0..7 should be (from left to right) "1 0 0 0 0 0 1 0"
Pos 0 : SRQ Enable -> 1 = ON
Pos 1 : Listen Always -> 0 = OFF
Pos 2..7 : address (0..31) -> here 00010 = 2
Power up everything, on the HP-71B
RESET HPIL (optional)
RESTORE IO
PRINTER IS :2
At that point the printer should be ready, use PRINT or PLIST to test it.
Sylvain
03-26-2017, 12:40 AM
Yes it works!
PRINT works now, but Im missing a few lines in the text, a check and cleaning of the printer head shows some corrosion unfortunately.
Well I might repair it if I get the time, or I can try to get some pens for my HP7470A.
I still need to get my HP9122S to work
MASSMEM IS :2 does not work, neither does INITIALIZE DISK:MASSMEM
03-26-2017, 01:06 AM
(03-26-2017 12:40 AM)Adalin Wrote:  I still need to get my HP9122S to work
The 9122S drive uses the SS/80 command protocol, which is not supported by the '71 HP-IL, and likely no other HP-IL controllers, including the HP-110 and HP-110+, which use the Amigo (and Filbert) protocols. The 9121 drive uses Amigo, so it's possible that could work if you have one.
03-26-2017, 01:16 AM
(03-26-2017 12:40 AM)Adalin Wrote:  Well I might repair it if I get the time, or I can try to get some pens for my HP7470A.
I can confirm that the HP-7470A HP-IB version also work.
Be aware that the plotter only understand HP-GL commands and that you will need to write BASIC programs in order to use it with the HP-71B.
The HP-41/71/75 only support Filbert protocol.
The HP-9122S only support SS/80 protocol.
The HP-9114A/B support both SS/80 and Filbert protocols.
Subset/80 (SS/80) Protocol Document
Sylvain
03-26-2017, 02:08 AM
(03-26-2017 01:16 AM)Sylvain Cote Wrote:  The HP-9114A/B support both SS/80 and Filbert protocols.
9114 Supports SS/80? Are you sure? I thought it only supported Filbert and Amigo. Where did you find docs that SS/80 is supported?
03-26-2017, 03:21 AM (This post was last modified: 03-26-2017 03:27 AM by Dave Frederickson.)
From the 9114A CE Handbook:
The HP 9114A Drive supports both the SUBSET/80 and the FILBERT
command set. FILBERT is the command set used by the 82161A
Cassette Tape Drive.
The 110, 110+, and 9114 all support SS/80.
https://groups.io/g/hpseries80/wiki/HP-8...ory-layout
Controller                         Amigo      Filbert    SS/80, CS/80
HP 110, 110+                       -          Filbert    SS/80
HP 110, 110+, AMIGO.SYS            Amigo      Filbert    SS/80
HP-41, HP-IL module                -          Filbert    -
HP-71B, HP-IL module               -          Filbert    -
HP-75C/D                           -          Filbert    -
Series-80, HP-IB I/F, MS-ROM       Amigo      -          -
Series-80, HP-IB I/F, MS+EMS-ROM   Amigo      -          SS/80
Series-80, HP-IL I/F               -          -          -
HP Integral PC, HP-IB I/F          -          -          SS/80
Peripheral                         Amigo      Filbert    SS/80, CS/80
9114A/B                            -          Filbert    SS/80
82161A Cassette Drive              -          Filbert    -
most HP-IB Drives (e.g. 9133D)     -          -          SS/80
some HP-IB Drives (e.g. 9133XV)    Amigo      -          -
ILPer/pyILPER Emulators            -          Filbert    -
03-26-2017, 09:00 AM
You can look at this document: mass storage for the HP Portable.
Amigo is supported too by manually adding the right device in CONFIG.SYS.
J-F
03-26-2017, 03:39 PM
Wow, refuted in stereo!
(03-26-2017 03:21 AM)Dave Frederickson Wrote:  The 110, 110+, and 9114 all support SS/80.
(03-26-2017 09:00 AM)J-F Garnier Wrote:  You can look at this document: mass storage for the HP Portable.
So, while 9114 and 110/110+ do apparently support SS/80 (SS stands for Sub Set, meaning not the full CS/80 protocol; SS was used on low-end HP drives), I don't think this changes the core answer that a 9122 cannot be accessed from a '71 via HP-IL/HP-IB adapter, at least out of the box.
Should have stuck with the answer and not generalized...
Note however that it appears SS/80 can be emulated using low-level HP-IL commands as I have an HP-75 program listing "CS80 driver for HP-75 <=>HP-IB<=>HP9121 drives" which almost surely has a typo since the 9121 drives use Amigo. Most likely the drive model listed should be 9122.
03-26-2017, 04:00 PM
Due to the different protocols, not all controllers can connect to all devices. For example, the Series 80 needs a Mass Storage ROM to access Amigo drives and the Extended Mass Storage ROM to access SS/80 drives and even with the HP-IL module, the Series 80 can't access a 9114. The 71 and 9121 are one of those combinations that weren't intended to work together.
You can run the built-in diagnostics if you want to test the drive.
03-26-2017, 05:19 PM
aw damn, well I guess I can use it for saving data from something sometime in the future..
Now to the last subject, Is it possible to communicate HP71b - HP71b with HPIL?
Can I use one device as the display from the other unit?
Or can I transfer data from one unit to the other one?
03-26-2017, 07:00 PM
(03-26-2017 05:19 PM)Adalin Wrote:  Now to the last subject, Is it possible to communicate HP71b - HP71b with HPIL?
Yes, it's described in the HP-IL Adapter manual; I captured that in this program, long ago:
10 ! PROG TO TAKE A FILE FROM ANOTHER HP-71
20 ! ROBERT PROSPERI 5 MAY 1984
30 ON ERROR GOTO 140
40 INPUT "Source file name? ";S$
50 INPUT "Target file name? ",S$;D$
55 IF D$="" THEN D$=S$
60 CONTROL ON
70 REMOTE :HP71
80 OUTPUT :HP71 ;"CONTROL OFF"
90 OUTPUT :HP71 ;"COPY "&S$&" TO :LOOP"
100 COPY :HP71 TO D$
110 LOCAL
120 DISP "File transferred successfully!"
130 STOP
140 E=ERRN @ E$=ERRM$ @ L=ERRL
150 DISP "Error ";E;" occurred at line ";L
160 DISP E$
170 STOP
180 END
The program is run on '71 A, used to 'take' a file from '71 B.
Steps:
0. Connect machines via HP-IL (other devices can be on the loop)
1. Turn on B
2. Turn on A
3. On B, do RESTORE IO
4. On A, do RESTORE IO
5. On A, RUN FILECOPY
6. Answer the prompts
7. Enjoy
The error handler originally did more, but I removed most of it when it was simplified; now it looks a bit silly, but it works.
The source file can be reasonably complex (FILE1, FILE2:PORT(3), FILE4:MAIN, etc.) but it's possible you could ask for something that chokes it...
03-29-2017, 06:23 PM
Hello
sorry for late answer I have been away on work related travels
But the program works perfectly!
