concatenation of prefixes with units and some problems
04-10-2017, 03:00 AM
(This post was last modified: 04-13-2017 12:49 PM by compsystems.)
A: Problem #1: I think prefixes should also be simplified/ evaluated or concatenated _m*_k → _m*k → _mk → 1E−3*1E3 → 0.001*1000 → 1 DEG MODE (4∡23°) * (5+7*i); [enter] 7.46962547135+33.5887584665*i // ok (4∡23°)*1_A * (5+7*i)*_Ohm; [enter] → 7.46962547135+33.5887584665*i_(A*Ohm) // ok (4∡23°)_m*_A * (5+7*i)*_k*_Ohm; [enter] → 7.46962547135+33.5887584665*i _(A*Ohm*k*m) // ok but USIMPLIFY( (4∡23°)_m*_A * (5+7*i)*_k*_Ohm ); [enter] → "Bad Argument Type" (current firmware =( ). Why? USIMPLIFY( (4∡23°)_m*_A * (5+7*i)*_k*_Ohm ); [enter] → 7.4696254713+33.5887584665*i _V ( In the firmware near future =) ) v:=(I_m_A)*(R_k_Ω) -> v:=(I_mA*R_kΩ) Screen capture ![]() Source of example, (exercises of electronic engineering) www.numerari.com/complex-numbers ![]() B: problem #2 (4∡23°)*_A * (5+7*i)*_Ohm; -> 7.46962547135+33.5887584665*i_(A*Ohm) OK [up][up] copy [ENTER]; 4 (∡i(115.+161.*i_(A*Ohm)) ? The entries of the history to the entry line must be able to recover without alteration, in many cases places redundant parentheses, in this case suppresses them and the problem is generated, because the angle argument expands to the right. 4: Please improve the pretty printing of the polar form of a complex number and other situations I have reported in this forum ∡(4,23) This notation is confusing, I have not seen it in any math book Thanks |
04-10-2017, 01:31 PM
(This post was last modified: 04-11-2017 12:11 PM by compsystems.)
RE: concatenation of prefixes with units and some problems
Hello another problem #3
The following statements, after closing and reopening the simulator, appears UNDEF (4∡23°) * (5+7*i); [enter] 7.46962547135+33.5887584665*i // ok (4∡23°)_A * (5+7*i)_Ohm; [enter] → 7.46962547135+33.5887584665*i _(A*Ohm) // ok (4∡23°)_m*_A * (5+7*i)_k*_Ohm; [enter] → 7.46962547135+33.5887584665*i _(A*Ohm*k*m) // ok ![]() ![]() |
04-11-2017, 01:16 AM
RE: Simplification/evaluation of prefixes and some problems
The prefixes are not used independently, it is always attached to the unit. Test the calculations in Home, the symbolic flow of the CAS can cause confusion.
![]() Viga C | TD | FB |
04-11-2017, 02:31 AM
(This post was last modified: 04-11-2017 01:31 PM by compsystems.)
RE: RE: concatenation of prefixes with units and some problems
I do not want to place them independently, are the templates that do this, the interpretation must be improved,
Following the steps (Home Mode) to enter the expression from template (4∡23°) + [Shift][templates(Units)][units] 1:prefix + [m] + E:Electricity [A] (4∡23°)_(m)_(A) [enter] "syntax error" // -> the parser must concatenate prefix with unit (4∡23°)_(mA) Otherwise, (4∡23°)_(m)*_(A) when the calculator is turned on again, show UNDEF problem #3 Now on CAS mode There is still a problem #4 (4∡23)_mA*(5+7*i)_kOhm; [enter] returns 7.46962547135+33.5887584665*i _(kOhm*mA) USIMPLIFY( [up][copy] USIMPLIFY(7.46962547135+33.5887584665*i_(kOhm*mA)); [enter] returns "Error: Bad argument type" because kOhm*mA Belongs to i (imaginary unit) and not to all expression as it should be A solution that planted in previous post, COPY must paste between parentheses, because sometimes objects need to operate between (), You all agree? So the previously referenced problems are solved (4∡23)_(mA)*(5+7*i)_(kOhm); [enter] returns 7.46962547135+33.5887584665*i_(kOhm*mA) // ok USIMPLIFY( [up][copy] USIMPLIFY( ( 7.46962547135+33.5887584665*i )_(kOhm*mA)); [enter] returns 7.46962547135+33.5887584665*i_(V) ok problem #5 DEG MODE Specifying in which mode is the angle (4∡23_deg)_mA*(5+7*i)_kOhm; returns (4∡23_deg)*(5+7*i)_kOhm*_mA; // ok USIMPLIFY(Ans); -> "Error: Unmatch control word" I think the CAS can not interpret (_deg) now HOME MODE (4∡23_deg)_mA*(5+7*i)_kOhm; or (4∡0.401425727959_rad)_mA*(5+7*i)_kOhm or (4∡0.401425727959_rad)_mA*(8.60232526704∡54.462322208_deg)_kOhm returns (34.4093010682∡77.4623222081)_(mA*kOhm) // ok USIMPLIFY(Ans); -> (34.4093010682∡77.4623222081)_(V) // ok PHP Code: EXPORT testAnglesOnPolarForm() |
User(s) browsing this thread:
