Fick Cardiac Output
04-11-2017, 04:22 AM
Fick Cardiac Output
Fick Cardiac Output Equations
The program FICK will calculate: * CO: Cardiac Output (L/min) * SV: Stroke Volume (ml) * CI: Cardiac Index (L/(min/m^2)) * SI: Stroke Index (ml/m^2) Given the following inputs: * Ca: Arterial blood oxygen (O2) content percentage * CvO2: Venous blood oxygen (O2) content percentage * VO2: Oxygen compulsion (in ml per pure oxygen gas per minute, STPD) * HR: Heart Rate in beats per minute (BPM) * Height in cm * Weight in kg STPD: Standard Temperature Pressure Density Conversion factors: 1 in = 2.54 cm, 12 in = 1 ft, 1 lb = 0.45359237 kg Formulas: CO = VO2 / (10 * (Ca - CvO2)) SV = CO * 1000/HR CI = CO/BSA SI = SV/BSA BSA: body surface area, measured in cm^3. There are several formulas, but the Fick program uses the simple approximation formula: BSA = √(weight * height)/60 HP Prime Program FICK Code: EXPORT FICK() Example: Inputs: * Ca: 19% * CvO2: 15% * VO2: 250 ml/min * HR: 64 * Height: 5 ft 11 in, 180.34 cm * Weight 196 lb, 88.90410452 kg Results: * CO: 6.25 L/min * SV: 97.65625 ml * CI: 2.96158586825 L/(min/m^2) * SI: 46.2747791914 ml/m^2 Source: Hewlett Packard. HP-67/97 User’s Library Solutions: Cardiac Corvallis, OR 1976 pg. 20 |
04-11-2017, 05:24 AM
RE: Fick Cardiac Output | |||
