Error! HPUpdaterCheck - Virtual calculator
04-13-2017, 11:51 PM
For some reason, many computers do not allow running downloaded programs in the %Temp% folder, the virtual calculator is not saved from that problem, it displays the following error:
[Image: 33864219112_95379df867_o.png]
It would be nice if the executable is stored in the Temp folder of the calculator itself %USERPROFILE%\Documents\HP Prime\Temp, Connectivity Kit uses its own Temp folder and does not cause problems.
It is also confusing that the program does not respond or seems frozen during the download:
[Image: 33980489406_9bf2623784_o.png]
Viga C | TD | FB
04-14-2017, 03:35 AM
RE: Error! HPUpdaterCheck - Virtual calculator
That is the old emulator I think. The new one does use its own temp folder and doesn't look like that in the update process anymore.
TW
