TI-36x PRO Equivalent
05-06-2017, 05:16 PM (This post was last modified: 05-07-2017 06:00 PM by Chris..)
Does HP make a SCIENTIFIC Calculator with a similar display and features as the TI-36x PRO?
One feature I want is the outputs to display as simplified values.
For example Sqrt(5^2+6^2) = Sqrt(61) not 7.8102....
05-06-2017, 08:49 PM
RE: TI-36x PRO Equivalent
as far as I know you need the CAS for that, so 49g+, 50g and Prime (and maybe some model before with additional libraries IIRC).
05-07-2017, 01:59 AM (This post was last modified: 05-07-2017 05:59 PM by Chris..)
I Don't actually mean CAS capability on a scientific calculator. I mean that: Entering the square root of 5 squared plus 6 squared would return Sqrt(61) instead of the decimal approximation.
some more examples are entering 65/4 would return 65/4 or entering 200/400 would return 1/2 and not 0.5.
If there is a proper name for that feature would anyone state it please?
Is the hp 300s+ the ti-36x pro or is it another calculator. Both have the multiview
05-07-2017, 06:29 AM
What you ask is done by the exact mode on the 50g, and it is using part of the case engine as far as I know. I don't think that system without a small Cas engine can do it on the hp side but here there are more experts so let's wait their suggestions.
05-07-2017, 08:16 AM
I would never trust a calculator giving Sqrt(5^2+6^2) = Sqrt(64)
Greetings,
    Massimo
05-07-2017, 05:23 PM
QPI
http://www.hpmuseum.org/software/qpi/42sqpi.htm
can simulate this function on a HP42S
05-07-2017, 06:03 PM
I meant 61 where I put "64" in sqrt(64) answers, I fixed in edit.
05-07-2017, 10:40 PM
+1 for QPI, although I have only used it on the 48G family
05-07-2017, 11:13 PM
(05-06-2017 05:16 PM)Chris. Wrote:  Does HP make a SCIENTIFIC Calculator with a similar display and features as the TI-36x PRO?
Yes, the 300s+ does this.
No, you don't need a CAS calculator for this. Many modern high end scientific calculators have a display mode that will attempt to display answers more accurately e.g. as fractions or surds (usually a button to change to floating point or a mode to always give floating point answers).
05-08-2017, 07:27 AM
(05-07-2017 05:23 PM)Dani R. Wrote:  QPI
(05-07-2017 10:40 PM)thomasross Wrote:  +1 for QPI, although I have only used it on the 48G family
I think a program like QPI is not what the OP is looking for. QPI tries to approximate a given number by a fraction or a term with logs and roots. This can be misleading. For instance, when set to 6 digit precision such a program may return "pi" even if the result of a calculation is simply 355/113 – and vice versa. The idea is not to have a number and then find a "nice" representation for it, but to display the exact result of a calculation (which can then be evaluated as a decimal approximation).
Also consider that QPI would return the result of √(3²+4²) simply as "5" and not as √25. ;-)
Dieter
