Multiplying fractions looks ugly
03-07-2014, 03:13 PM
If one enters something like $$\frac{1}{4}\cdot\frac{3}{4}$$ the Prime formats it like $$\frac{\frac{1}{4}*3}{4}$$
Although this is mathematically correct this double fraction just looks ugly in my opinion (I don't even want to mention the multiplication "*").
The only way to circumvent this auto-uglyfication is to enter a space before the second fraction: $$\frac{1}{4}*\sqcup\frac{3}{4}$$
However if one copies such a "nice formatted" expression like this from the history to the input its uglyfied again :-(
So (one of) my wish to HP for the next firmware: Switch off the expression uglyfier ;-) and use a proper multiplication dot.
03-07-2014, 06:06 PM (This post was last modified: 03-07-2014 06:12 PM by Mark Hardman.)
RE: Multiplying fractions looks ugly
(03-07-2014 03:13 PM)Stefan Wrote:  If one enters something like $$\frac{1}{4}\cdot\frac{3}{4}$$ the Prime formats it like $$\frac{\frac{1}{4}*3}{4}$$
PEDMAS again...
You've entered the expression:
1/4*3/4
Using the proper rules of the order of operations, the expression is parsed as:
1 divided by 4 times 3, and then all of that divided by 4.
Given PEDMAS, the formatting of the original result is correct.
If you want, you could enter the expression as:
(1/4)*(3/4)
Which will format the result the way you want (3/16).
Mark Hardman
Ceci n'est pas une signature.
03-07-2014, 06:34 PM (This post was last modified: 03-07-2014 06:36 PM by Mark Hardman.)
(03-07-2014 03:13 PM)Stefan Wrote:  However if one copies such a "nice formatted" expression like this from the history to the input its uglyfied again :-(
Even if the expression is entered as:
(1/4)*(3/4)
You are correct. If selected from the history, the command line is loaded with the "uglyfied" formatting.
\(\frac{\frac{1}{4}*3}{4}\)
Mark Hardman
03-07-2014, 06:36 PM
I don't see it making any change when I copy it down... ?
TW
03-07-2014, 06:39 PM
(03-07-2014 06:36 PM)Tim Wessman Wrote:  I don't see it making any change when I copy it down... ?
Are you in CAS mode?
Mark Hardman
03-07-2014, 06:47 PM
Nope, that would explain it. Thanks!
TW
