(48G) Statistics: Mid-range & Estimator of Standard Deviation
05-31-2017, 09:35 AM
(This post was last modified: 06-15-2017 01:47 PM by Gene.)
A lazy way to find the average of a set of data is to take half of the sum of max & min values, which is in fact the correct method to find the middle of the range of values.
The programme below finds the mid-range value, MR, for a list of values. An easy way to quickly calculate a reasonable approximation to the standard deviation of the values is to divide MR by 4. Code:
