Smith Chart program
06-09-2017, 04:52 PM
Smith Chart program
I still have not really figured out how to create a source file, and I currently do not have a computer with the simulator running on it, so I typed this into Word. There may be typos and some odd characters.
Anyway, this program displays a Smith chart and if you tap a point will display many of the relevant data about that point, I.e., Z, X, Gamma, Return Loss, VSWR and Q.
DISPSMITH(F);
EXPORT SMITH()
LOCAL pp,r,p2,cw,cb,x1,y1,m1;
LOCAL ff,cc,vv,ll,x2,y2;
LOCAL cr,lc,qq,zz,xx;
STARTAPP("Function");
x2:=1.2;
y2:=0,0;
cw:=RGB(255,255,255);
cb:=RGB(0,0,0);
cr:=RGB(255,0,0);
Xmin:=-1.4521;
Xmax:= 1.4521;
Ymin:=-1.0;
Ymax:=1.0;
ff = 1.0; // GHz
DISPSMITH(ff);
WHILE 1 DO // forever
L1:= WAIT(-1);
m1:= B→R(L1(1)); //Note: May need editing!
IF m1=3 THEN
x1:= B→R(L1(2)); //Note: May need editing!
y1:= B→R(L1(3)); //Note: May need editing!
L2 := PX→C(x1,y1); //Note: May need editing!
IF L2(1) > -1.4 AND L2(1) < -0.4 THEN
IF L2(2) < 1 AND L2(2) > 0.6 THEN
BREAK;  // Tapped "QUIT"
IF L2(1) > 0.7 AND L2(1) < 1.4 THEN
INPUT(ff, "ENTER FREQUENCY", "FREQUENCY", "IN GHZ");
DISPSMITH(ff);
Z1:= L2(1)+i*L2(2); // Reflection Coef.
Z2:= 50*((1+Z1)/(1-Z1)); // Impedance
IF ABS(Z1) ≥ 1 THEN // May need Editing
CONTINUE; // Make sure we are inside the positive Z Chart
// Undraw, then draw the cursor
LINE(x2+0.05,y2,x2-.05,y2,cw);
LINE(x2,y2+.05,x2,y2-.05,cw);
x2:=L2(1);
y2:=L2(2);
LINE(x2+0.05,y2,x2-.05,y2,cr);
LINE(x2,y2+.05,x2,y2-.05,cr);
vv:= (1+ABS(Z1))/(1-ABS(Z1)); //VSWR
qq:= ABS(IM(Z2)/RE(Z2)); // Q
zz:= ABS(RE(Z2));
// Autoscale May need editing
CASE
IF zz≥1000 THEN L2(3):=STRING(zz,2,0); END;
IF zz≥100 THEN L2(3):=STRING(zz,2,1); END;
IF zz≥10 THEN L2(3):=STRING(zz,2,1); END;
IF zz≥1 THEN L2(3):=STRING(zz,2,2); END;
DEFAULT L2(3):=STRING(zz,2,2);
RECT(-1.4,-0.55,-0.75,-0.67);
TEXTOUT("R="+L2(3)+" Ω ", -1.4,-0.55,0,cb,100,cw); // 'Ω' is unicode 2126
IF ABS(Z1) ≠ 0.0 THEN // needs editing for not equal
ll:= 10*LOG(ABS(Z1)^2); // return loss
ELSE
ll:= -99;
L2(3):= STRING(ll,2,2);
RECT(-1.4,-0.85,-0.60, -0.97);
TEXTOUT("RL="+L2(3)+ " dB",-1.4,-0.85,0,cb,100,cw);
xx:= ABS(IM(Z2));
CASE
IF xx≥1000 THEN L2(3):=STRING(xx,2,0); END;
IF xx≥100 THEN L2(3):=STRING(xx,2,1); END;
IF xx≥10 THEN L2(3):=STRING(xx,2,1); END;
IF xx≥1 THEN L2(3):=STRING(xx,2,2); END;
DEFAULT L2(3):=STRING(xx,2,2);
RECT(-1.4,-0.70,-0.70,-0.82);
IF(IM(Z2) ≥ 0) THEN // Needs to be edited to greater than or equal
L2(4):= " j";
ELSE
L2(4):= "-j";
END
TEXTOUT("X="+L2(4)+L2(3)+" Ω", -1.4,-0.70,0,cb,100,cw); // 'Ω' is unicode 2126
RECT(-1.4,-1.0,-0.63,-1.12);
IF y2 ≥ 0.0 THEN
lc:=y2/(2*π*ff);
L2(3) :=STRING(lc,2,3);
TEXTOUT(“L=”+L2(3)+”nH”,-1.4,-1.0,0,cb,100,cw);
ELSE
Lc:=ABS(y2)*2* π*ff;
TEXTOUT(“C=”+L2(3)+”pF”,-1.4,-1.0,0,cb,100,cw);
RECT(0.8, -0.70,1.4,-0,82);
L2(3):=STRING(qq,2,2);
TEXTOUT(“Q=”+L2(3),0.8,-0.7,0,cb,100,cw);
RECT(0.8,-0.85,1.4,-0.97);
L2(3):=STRING(ABS(Z1),2,2);
TEXTOUT(“Γ=”+L2(3), 0.8,-0.85,0,cb,100,cw); // may need editing “Γ” is Unicode 0393
RECT(0.6,-1.0,1.4,-1.12);
L2(3):=STRING(vv,2,2);
TEXTOUT(“VSWR=”+L2(3)+”:1”,0.6,-1.0,0,cb,100,cw);
END; // IF m1
END; // WHILE 1
END; // SMITH
DISPSMITH(f)
LOCAL pp, r, cl;
RECT();
L9:=C→PX(0,0);
pp:=320/(Xmax-Xmin);
LINE_P(L9(1)-pp,L9(2),L9(1)+pp,L9(2));
ARC_P(L9(1),L9(2),pp);
r:=pp/(1+50/50);
ARC_P(L9(1)+pp-r,L9(2),r);
r:=pp/(1+100/50);
r:=pp/(1+25/50);
r:=pp/(1+12.5/50);
r:=pp/(50/50);
ARC_P(L9(1)+pp,L9(2)-r,r,π,3*π/2);
ARC_P(L9(1)+pp,L9(2)+r,r,π/2,π);
r:=pp/(25/50);
ARC_P(L9(1)+pp,L9(2)-r,r,3*π/2-0.95,3*π/2);
ARC_P(L9(1)+pp,L9(2)+r,r,π/2,π/2+.95);
r:=pp/(75/50);
ARC_P(L9(1)+pp,L9(2)-r,r,3*π/2-2,3*π/2);
ARC_P(L9(1)+pp,L9(2)+r,r,π/2,π/2+2);
r:=pp/(12.5/50);
ARC_P(L9(1)+pp,L9(2)-r,r,3*π/2-0.5,3*π/2);
ARC_P(L9(1)+pp,L9(2)+r,r,π/2,π/2+.5);
Cl:=RGB(0,0,255);
TEXTOUT(“50”,0,0,1,cl);
TEXTOUT(“25”,-0.33333,0,1,cl);
TEXTOUT(“12.5”,-0.80,0,1,cl);
TEXTOUT(“100”,0.33333,0,1,cl);
TEXTOUT(“50”,-0.9,1,1,cl);
TEXTOUT(“25”,-0.55,-0.75,1,cl);
TEXTOUT(“12.5”,-0.90,-0.30,1,cl);
TEXTOUT(“75”,0.4,-0.85,1,cl);
TEXTOUT(“QUIT”,-1.4,0.9);
L2(3) = STRING(f,2,3);
TEXTOUT(L2(3)+” GHz”,0.8,0.9);
END; // DISPSMITH
06-09-2017, 05:10 PM (This post was last modified: 06-09-2017 05:20 PM by Freire.)
RE: Smith Chart program
A source file is just a plain text(.txt) file with your code inside.
The reason for that is HP programs or apps(.hpprgm or .hpappdir) they cannot be edited outside of HP connectivity Kit.
The way you posted inside a code tag is just as effective as a source file.
06-10-2017, 11:21 AM
HP Prime code files can be edited with any text editor. It's simply a case of copy/pasting them into/out from the code editor of the CK.
06-12-2017, 06:57 PM
(06-10-2017 11:21 AM)grsbanks Wrote:  HP Prime code files can be edited with any text editor. It's simply a case of copy/pasting them into/out from the code editor of the CK.
And figuring out the Unicode numbers for all the darn special keys. In this case, I currently don't have a CK available.
06-15-2017, 02:51 PM
Now that we have that out of the way, any comments on the program? Other than it is badly written?
Any questions about Smith Charts?
06-18-2017, 12:13 PM
Tabulating the code with the PrimePAD you can see that there is an end of more,
PHP Code:
DISPSMITH(F);
EXPORT SMITH()
    LOCAL pp
x2:=1.2;
y2:=0.0;
cb:=RGB(0,0,0);
cr:=RGB(255,0,0);
Xmin:=-1.4521;
Xmax:= 1.4521;
Ymin:=-1.0;
Ymax:=1.0;
ff 1.0// GHz
DISPSMITH(ff);
    WHILE
DO // forever
L1:= WAIT(-1);
IF m1=3 THEN
            x1
IF L2(2) < AND L2(2) > 0.6 THEN
            IF
                    INPUT
(ff"ENTER FREQUENCY""FREQUENCY""IN GHZ");
DISPSMITH(ff);
IF ABS(Z1≥ 1 THEN // May need Editing
x2:=L2(1);
y2:=L2(2);
zz:= ABS(RE(Z2));
CASE
                IF
                IF
                IF
                IF
                DEFAULT
IF ABS(Z1≠ 0.0 THEN // needs editing for not equal
ELSE
ll:= -99;
xx:= ABS(IM(Z2));
CASE
                IF
                IF
                IF
                IF
                DEFAULT
            IF(
IM(Z2≥ 0THEN // Needs to be edited to greater than or equal
L2(4):= " j";
            ELSE
L2(4):= "-j";
END
            TEXTOUT
            IF
y2 ≥ 0.0 THEN
                lc
:=y2/(2*π*ff);
TEXTOUT(“L=+L2(3)+”nH”,-1.4,-1.0,0,cb,100,cw);
            ELSE
Lc:=ABS(y2)*2π*ff;
TEXTOUT(“C=+L2(3)+”pF”,-1.4,-1.0,0,cb,100,cw);
TEXTOUT(“Q=+L2(3),0.8,-0.7,0,cb,100,cw);
TEXTOUT(“Γ=+L2(3), 0.8,-0.85,0,cb,100,cw); // may need editing “Γ” is Unicode 0393
TEXTOUT(“VSWR=+L2(3)+:1”,0.6,-1.0,0,cb,100,cw);
END// IF m1
END// WHILE 1
END// SMITH
DISPSMITH(f)
    LOCAL pp
rcl;
RECT();
L9:=C→PX(0,0);
r:=pp/(1+50/50);
r:=pp/(1+100/50);
r:=pp/(1+25/50);
r:=pp/(1+12.5/50);
r:=pp/(50/50);
r:=pp/(25/50);
r:=pp/(75/50);
r:=pp/(12.5/50);
Cl:=RGB(0,0,255);
END// DISPSMITH
12-25-2017, 06:22 PM
Nice Smith Chart. Smile
Being a newbie, wanted to fiddle to learn. Here is your chart with the ability to paint up to 3 parameters (any three) in RGB. Works, but very slow - 6-8 minutes to paint.
Cool looking.
If anyone knows how to speed this up, please share.
Here is the code:
Attached File(s)
.txt  SmithChartGradients.txt (Size: 11.86 KB / Downloads: 31)
