200LX: Open documents directly from Filer?
06-12-2017, 02:16 PM
I know 100BUDDY allows you to hit ENTER twice to open documents (.pdb, .gdb, .wk1, etc.) with the appropriate application directly from the Filer, but it also does a ton of other stuff, 95% of which I don't need or want. It seems to take up about 30-40 KB of RAM while loaded, too.
Anybody know of a smaller TSR that gives you just this Filer functionality without all the extras?
06-13-2017, 05:53 PM
RE: 200LX: Open documents directly from Filer?
(06-13-2017 02:58 PM)Mike (Stgt) Wrote:  Take PNS from Andreas Garzotto. Note in SUPER: "Allows multiple program launch selections based on file extensions in Filer. Also useful to enhance for example MM/LX and Post/LX. Freeware." Still available here.
PNS works nice with Craig Payne's KBuf128.SYS (avoids key buffer overflow) and KS.COM, a Key Stuffer. Both not found any more where I once discovered it. Tempi passati.
Ciao.....Mike
PS: or use X-Finder -- and you will never use the Filer again. Smile
Oh, nice. I was able to dig up ks.com and kbuf128.sys from the 2000 CD InfoBase archive I downloaded a while back. And at that point, I didn't even really need to get PNS involved, since I don't (yet) need a menu with multiple actions for each file, I just want them to open in the given app. So I put some ksx.com entries (a version made for use with FILER.INI that uses @ instead of \) into my FILER.INI, and that seems to be working well.
X-Finder looks pretty cool; I might spend a little time figuring out what kind of overhead is involved (both time needed for installation and configuration, and system RAM for running the thing).
Thanks!
