Programming Challenge
06-15-2017, 12:31 PM
Write a routine to convert a number in base 2-16 to/from base 1.
Neatness counts.
Tom L
Cui bono?
06-19-2017, 09:27 AM
RE: Programming Challenge
Base 1? that will be hard!
the code bellow should do it for you...
One liners for both functions...
export baseTo10(number, base) // number expressed as a list of coefitiants, most significant digit first...
begin
return Σlist(makelist(number(I)*base^(size(number)-I), I, 1, size(number)));
end;
// example baseTo10({1, 0, 1, 0, 1}, 2) -> 21
export from10ToBase(number, base)
begin
return makelist(floor((number/base^I) mod base), I, 0, log(number, base));
end;
// example from10ToBase(21, 2) -> {1, 0, 1, 0, 1}
06-19-2017, 10:46 AM
(06-19-2017 09:27 AM)cyrille de brébisson Wrote:  Hello,
Next challenge: provide object TYPE (number and description) for the TYPE coefitiants you've described for elements of the list, I didn't see that one in the User Guide. <g>
Very nice programming Cyrille! I took liberty of saving both programs for future use, but I did change the name so they would appear next to each other (or very nearly so) in my master program catalog:
baseTO10(number,base) and it's cousin base10TO(number,base)
06-20-2017, 12:42 AM
There are a number of conversion programs available in the software library that will do the conversions you seek, and then some.
Graph 3D | QPI | SolveSys
User(s) browsing this thread:
