Spreadsheet app insert column
06-18-2017, 04:12 PM
Is there a way to insert a column? Nothing obvious comes up when I highlight the heading.
06-18-2017, 07:20 PM
RE: Spreadsheet app insert column
Simply enter for example "=Row^2", that is the way to enter formulas for a whole column.
Arno |
06-19-2017, 12:09 AM
Not really what I want. I have an existing sheet and I need to add a column between two existing ones. Eg, I have net and "purchase price" and I want to put "additional" and "down payment" between them.
06-19-2017, 09:13 AM
Unfortunately, there is no easy way to do so... The easiest might be a copy/paste operation Cyrille Although I work for the HP calculator group, the views and opinions I post here are my own. I do not speak for HP. |
06-22-2017, 10:25 PM
RE: Spreadsheet app insert column | |||
06-26-2017, 06:14 AM
hello,
Sorry, yes, formulas don't get updated. Cyrille Although I work for the HP calculator group, the views and opinions I post here are my own. I do not speak for HP. |
06-26-2017, 10:45 PM
You can use the programs below to insert and delete columns:
PHP Code: EXPORT InsertCol(c) Example: If you want to insert a column at B just go to the home or cas view and type InsertCol(2). Similar for DeleteCol. I'm working on a similar method to insert and delete rows. Eventually, as time permits, I plan to use the Curser variable to locate where to insert or delete, and hijack the plot key to display a pop up menu asking how many rows or columns. -road |
